With the right help, even work can be more enjoyable and fulfilling. Designed with ergonomic features to boost your work comfort and productivity, the BL2205PT is the winning choice for any workstation.
Ergonomic design
With height, pivot, swivel, and tilt adjustments, the BenQ BL2205PT offers a flexible height adjustment system (HAS) that ensures optimal ergonomics for extended use. -
Vivid visuals
Experience the brilliance of 16.7 million colors and a 72% NTSC color gamut on a 21.5-inch Full HD 1080p display, enhanced with an anti-glare coating for reduced eye strain. -
Seamless connectivity
Equipped with DVI, DisplayPort, and VGA interfaces, this LED-backlit LCD monitor offers versatile connectivity options for both legacy and modern devices. -
Enhanced productivity
Features like Low Blue Light Mode and Flicker-Free technology work to reduce eye fatigue, allowing for longer periods of productivity without discomfort. -
Efficient performance
The BenQ BL2205PT is ENERGY STAR certified, ensuring energy efficiency with a typical power consumption of just 21 W, making it an eco-friendly choice for your workspace.
- BenQ BL2205PT - BL Series - LED monitor - Full HD (1080p) - 21.5"
- LED-backlit LCD monitor - 21.5"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 12000000:1 (dynamic)
- Response Time
- 2 ms (gray-to-gray), 5 ms (tr - tf)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% NTSC
- Input Connectors
- DVI, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare
- Non-glossy black
- 51 cm x 21.4 cm x 47.4 cm
- 5 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- Display Type
- Diagonal Size
- 21.5"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 72% NTSC
- Response Time
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- HDCP, Low Blue Light Mode, Ultra-Flexible Height Adjustment System (HAS), 72% NTSC colour gamut
- Non-glossy black
- 51 cm x 21.4 cm x 47.4 cm - with stand
- 5 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 1 Watt
- DVI , DisplayPort , VGA , Audio line-in , Audio line-out
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 90
- Rotation Angle
- 90
- Height Adjustment
- 110 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), Flicker-free technology
- Cables Included
- 1 x VGA cable - 1.5 m
- Security Slot Type
- Kensington security slot
- Power Consumption (Typical)
- 21 Watt
- Power Consumption Sleep
- 0.5 Watt
- OS Required
- Microsoft Windows 7 / 8 / 8.1
- Dimensions & Weight Details
- With stand - width: 51 cm - depth: 21.4 cm - height: 47.4 cm - weight: 5 kg , Without stand - width: 51 cm - depth: 5.04 cm - height: 30.2 cm
Sustainability Information
- ENERGY STAR Certified
C2G 2m DisplayPort Male to HD Male Adapter Cable - Black | In Stock | £17.25 |
C2G 3m DisplayPort Cable with Latches M/M - Black | In Stock | £13.78 |
C2G 20cm DisplayPort Male to HDMI Female Adapter Converter Black | In Stock | £16.49 |
