BenQ 21.5IN LCD G2255  16:9 5MS
Quicklinx: 832JWS00 Mfr#: 9H.L8CLB.QPE
Enjoy the spacious view while reviewing work documents or catching up on the latest show online! Featuring a 21.5"W 16:9 LCD display, 40000:1 dynamic contrast ratio, DVI connector and 5ms response time, the BenQ G2255 is built to deliver the best picture quality for work or play!
  • A visual performance for the best enjoyment in life
    An enjoyable addition to your everyday home or work life, the G2255 gives you crisp and accurate viewing at all times.
  • 40000:1 dynamic contrast ratio offers you the finest details
    The G2255 comes with a dynamic contrast ratio of 40000:1 to add color depth and definition to darkened and complex motion pictures, so that everything you see, from the brightest white to the darkest black, is perfectly rendered to deliver the clearest, smoothest picture performance during movies and video games.
  • Full HD 1080p 16:9 visual perfection
    The BenQ G2255 supports the Full HD 1080p with 16:9 aspect ratio - allowing the subtlest details to stand out with richer, more realistic colors, making your viewing experience even more absorbing.
  • Superior response time
    Enjoy high dynamic videos without ghosting or other artifacts with 5ms response time.
  • Senseye 3 visual solution to your everyday viewing needs
    Experience the truest colors of the world with the BenQ Senseye Human Vision technology. With the help of its six proprietary calibration techniques, Senseye 3 delivers only the best viewing quality in each of its six pre-set viewing modes - standard, movie, game, photo, sRGB, and eco - with the eco mode especially designed to save power and money.
  • Win 7 compatible
    The G2255 has passed Windows 7 certification and are fully compatible with Windows 7 color systems. Plug in the G2255 to your computer, and Windows 7 will recognize it instantly, making setup and connection effortless.
  • ecoFACTS label
    ecoFACTS can tell you how eco-friendly BenQ products are! ecoFACTS declares BenQ's greatest efforts on the replacement of hazardous substances, material selection, packaging design, energy-saving design and other aspects of the products.
  • Energy Star qualified
    The G2255 complies with the requirement of Energy Star program for computer monitors, version 5.1. Now you can enjoy saving energy and money as well as keeping the Earth looking great!
BenQ G2255 - LCD monitor - Full HD (1080p) - 21.5"
LCD monitor - 21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.248 mm
Brightness
200 cd/m²
Contrast Ratio
600:1 / 40000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Colour Gamut
72%
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
Glossy black
52.4 cm x 17.3 cm x 39.9 cm
3.7 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
TUV, RoHS
Display Type
LCD monitor / TFT active matrix
Diagonal Size
21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
200 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72%
Response Time
5 ms
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
24 - 83 kHz
Video Bandwidth
205 MHz
Horizontal Viewing Angle
90
Vertical Viewing Angle
65
Controls & Adjustments
Colour temperature
sRGB colour management, HDCP, Senseye Human Vision Technology, Senseye 3 Technology
Glossy black
3.7 kg
VGA , DVI-D
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
TUV, RoHS
Security Slot Type
Kensington security slot
Power Supply
Internal
Power Consumption (Typical)
30 Watt
Power Consumption Stand by / Sleep
0.3 Watt
Sustainability Information
ENERGY STAR Certified
Limited warranty - 2 years - pick-up and return
