The GW2270 VA LED monitor brings viewing pleasure to everyday work and play with exquisite details on the exterior and striking visual performance delivered by 3000:1 high contrast ratio, 178°/178°wide-viewing angle and BenQ's eye-caring design, which consists of BenQ's Flicker-free technology and Low Blue Light modes.
Low Blue Light Technology
Unique BenQ Low Blue Light Technology is designed to filter out harmful blue light, effectively diminishing eye fatigue and irritation. -
Flicker-free
Flicker-free eliminates flickering at all brightness levels and reduces eye fatigue effectively. Conventional LCD screens flicker at the rate of 250 times per second. Your eyes may not see the flickers but they can certainly feel them. So relieve your eyes from the uncomfortable flickering effect by switching to a BenQ flicker-free monitor. -
3000:1 ultra-high native contrast for depth and definition
Ultra-high 3000:1 native contrast, 3X higher than standard panels, adds astonishing color depth and definition to complex dark images with exquisite subtlety and clarity. High native contrast also enables infinite dynamic contrast to far exceed the highest expectations. -
178°/178° wide viewing angles
Advanced VA (Vertical Alignment) panel technology delivers truly authentic colors and ultra-sharp details from left, right, above and below with 178°/178° viewing angles for an unsurpassed viewing experience. -
8-bit color display
With the ability to render 16.7 million color shades simultaneously, you can expect true colors, silky transitions and impeccable image quality.
- BenQ GW2270 - LED monitor - Full HD (1080p) - 21.5"
- LED-backlit LCD monitor - 21.5"
- Panel Type
- A-MVA+
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 3000:1 / 20000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72%
- Input Connectors
- DVI, VGA
- Tilt
- Voltage
- AC 100/120/230 V
- Black
- 50.6 cm x 17.8 cm x 40 cm
- 3.4 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- Display Type
- Diagonal Size
- 21.5"
- Panel Type
- A-MVA+
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 72%
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- HDCP, Advanced Motion Accelerator (AMA) technology, Dynamic Power Saving (DPS), Low Blue Light Mode
- Black
- 50.6 cm x 17.8 cm x 40 cm - with stand
- 3.4 kg
- DVI-D , VGA
Mechanical
- Tilt
- Tilt Angle
- -5/+20
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), Flicker-free technology
- Cables Included
- 1 x VGA cable - 1.5 m
- Security Slot Type
- Kensington security slot
- Input Voltage
- AC 100/120/230 V
- Power Consumption Sleep
- 0.5 Watt
- OS Required
- Microsoft Windows 7 / 8 / 8.1
- Dimensions & Weight Details
- With stand - width: 50.6 cm - depth: 17.8 cm - height: 40 cm - weight: 3.4 kg , Without stand - width: 50.6 cm - depth: 5.1 cm - height: 30.4 cm
Sustainability Information
- ENERGY STAR Certified
