Belkin Wireless USB Adapter N600
Quicklinx: 8LDJWS00 Mfr#: F7D4101az
  • IEEE 802.11n
The Play Wireless USB Adapter connects your laptop or desktop computer to your wireless network. When matched with a Belkin Play or Play Max Wireless Router at the center of your network, you'll have the fastest speeds possible to easily stream HD video or game online.
  • Enhanced security
    With support for 128-bit and 64-bit WEP, WPA, and WPA2 encryption algorithms, this wireless USB adapter ensures your network connection remains secure against unauthorized access.
  • Versatile connectivity
    Featuring compatibility with IEEE 802.11a, 802.11b, 802.11g, and 802.11n standards, the adapter offers flexible connection options across both 2.4 GHz and 5 GHz Wi-Fi bands, catering to a wide range of networking environments.
  • Seamless integration
    The USB 2.0 interface ensures easy Plug-and-Play setup, making it straightforward to integrate into your existing setup without the need for complex installation procedures.
  • Optimized performance
    With a data transfer rate of up to 300 Mbps, this adapter is designed to provide fast and efficient connectivity, enhancing your online experience whether you're streaming, gaming, or browsing.
Belkin Play Wireless USB Adapter - network adapter - USB 2.0
Network adapter
External
Interface (Bus) Type
USB 2.0
802.11a, 802.11b/g/n
Data Transfer Rate
300 Mbps
Frequency Band
2.4 GHz, 5 GHz
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Wi-Fi Protected Setup
Microsoft Windows XP SP2, Microsoft Windows 7, Microsoft Windows Vista
Network adapter
External
USB 2.0
Wireless
Data Transfer Rate
300 Mbps
Frequency Band
2.4 GHz, 5 GHz
VPN support, WPS, IPSec passthrough
Aerial
Antenna
Internal
1 x USB 2.0 - 4 pin USB Type A
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2
Software Included
Drivers & Utilities
