The Play Wireless USB Adapter connects your laptop or desktop computer to your wireless network. When matched with a Belkin Play or Play Max Wireless Router at the center of your network, you'll have the fastest speeds possible to easily stream HD video or game online.
Enhanced security
With support for 128-bit and 64-bit WEP, WPA, and WPA2 encryption algorithms, this wireless USB adapter ensures your network connection remains secure against unauthorized access. -
Versatile connectivity
Featuring compatibility with IEEE 802.11a, 802.11b, 802.11g, and 802.11n standards, the adapter offers flexible connection options across both 2.4 GHz and 5 GHz Wi-Fi bands, catering to a wide range of networking environments. -
Seamless integration
The USB 2.0 interface ensures easy Plug-and-Play setup, making it straightforward to integrate into your existing setup without the need for complex installation procedures. -
Optimized performance
With a data transfer rate of up to 300 Mbps, this adapter is designed to provide fast and efficient connectivity, enhancing your online experience whether you're streaming, gaming, or browsing.
- Belkin Play Wireless USB Adapter - network adapter - USB 2.0
- Network adapter
- Form Factor
- External
- Interface (Bus) Type
- USB 2.0
- Data Link Protocol
- 802.11a, 802.11b/g/n
- Data Transfer Rate
- 300 Mbps
- Frequency Band
- 2.4 GHz, 5 GHz
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Wi-Fi Protected Setup
- System Requirements
- Microsoft Windows XP SP2, Microsoft Windows 7, Microsoft Windows Vista
- 2-year warranty
- Network adapter
- Form Factor
- External
- USB 2.0
- Connectivity Technology
- Wireless
- 300 Mbps
- Frequency Band
- 2.4 GHz, 5 GHz
- VPN support, WPS, IPSec passthrough
Aerial
- Antenna
- Internal
- Connections
- 1 x USB 2.0 - 4 pin USB Type A
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA, WPA2
- Software Included
- Drivers & Utilities
- OS Required
- Limited warranty - 2 years
