Belkin Wireless Keyboard and Mouse English
Quicklinx: J7GMWS00 Mfr#: BBZ010uk
More than 50 In Stock
£9.66 ex VAT
£11.59 inc VAT
The Belkin Connect keyboard and mouse set delivers a seamless wireless experience with its 2.4 GHz connectivity technology, allowing for multimedia control and efficient operation. Designed with a full-size QWERTY layout and numeric keypad, this set is suitable for both productivity and comfort, featuring adjustable height for personalized ergonomics. The spill-proof and accident-proof design adds reliability, ensuring the keyboard and mouse can withstand everyday use and small mishaps without compromising performance. Enjoy an easy setup with Plug-and-Play compliance, making this keyboard and mouse set a practical choice for any workspace.
  • Responsive wireless connectivity
    The wireless functionality operates on a 2.4 GHz frequency, providing a reliable connection for both the keyboard and mouse without the hassle of wires.
  • Spill-proof design
    The keyboard is designed to resist spills, safeguarding against accidental liquid contact and prolonging its lifespan in everyday environments.
  • Full-size ergonomic layout
    Featuring a full-size QWERTY layout including a numeric keypad, this keyboard allows for efficient typing and enhances productivity for various tasks.
  • Customizable comfort
    With adjustable height settings, users can modify the keyboard height to their preference, ensuring comfortable and ergonomic usage during long hours.
  • Simple Plug-and-Play setup
    The Plug-and-Play compliance allows for easy installation, enabling users to get started with their new keyboard and mouse set immediately after unboxing.
Belkin Connect - keyboard and mouse set full size - QWERTY - UK Input Device
Keyboard and mouse set
2.4 GHz
Wireless Receiver
USB wireless receiver
Wireless
Localization and Layout
QWERTY UK
Hot Keys Function
Multimedia
Protection
Spill-proof, accident-proof
Numeric Keypad
Pointing Device
Mouse - wireless - optical
Buttons Qty
3
2.4 GHz
Wireless Receiver
Dimensions (WxDxH) / Weight
Keyboard: 43.2 cm x 12.9 cm x 2 cm / 471 g , Mouse: 6.9 cm x 10.9 cm x 3.8 cm / 82 g
Wireless
Hot Keys Function
Multimedia
QWERTY UK
Adjustable Height
Protection
Numeric keypad
Pointing Device
Mouse - wireless
Buttons Qty
3
Movement Detection Technology
Optical
Movement Resolution
1200 cpi
Batteries
Plug and Play
Microsoft Windows
Brand: Belkin
