Belkin Wireless AC1200 Modem Router  (BT Line)
Quicklinx: 8LDSWS00 Mfr#: F9J1106uk
  • IEEE 802.11n
The Belkin AC 1200 DB Wi-Fi Dual-Band AC+ Gigabit Modem Router offers a new level of reliability, speed and coverage for all your Wi-Fi devices. Now the whole family can watch shows and play games online with tablets, smartphones, or Smart TV - all at the same time.
AC is next-generation Wi-Fi, providing greatly improved coverage and speeds up to 2.8x faster than traditional N routers*. The Belkin AC 1200 also enhances mobile device performance, and works seamlessly with Wi-Fi N' and G' devices. Get the most out of all your wireless devices and take home networking to the next level with the Belkin AC 1200 DB Wi-Fi Dual-Band AC+ Gigabit Router.
* Up to 2.8x faster physical data rate when compared to 802.11n Wi-Fi routers using two antennas to transmit and receive data. Actual speeds will vary depending on a number of factors. In order to achieve the best performance, router must be used with a compatible wireless device.
Up to 2.8x Faster Than N Technology*
Optimized performance for a new level of speed and reliable coverage to all your Wi-Fi devices.
DUAL-BAND SPEED
Get the fastest dual-band speeds for video streaming and gaming--up to 300Mbps (2.4GHz) + 867Mbps (5GHz)† for delivering maximum speed to multiple devices.
UNITERRUPTED HD MOVIE STREAMING
Belkin's proprietary Intellistream QoS (Quality of Service) automatically prioritizes video and gaming.
HIGH-POWERED SIGNAL
Exclusive MultiBeam antenna technology provides maximum coverage virtually anywhere in the home.
PARENTAL CONTROL
Blocks unsafe and inappropriate content automatically for all the devices on your network.
BACKWARDS COMPATIBLE
Works seamlessly with N' and G' Wi-Fi devices.
FOUR GIGABIT PORTS
Connect multiple wired devices at gigabit speeds.
*Up to 2.8x faster physical data rate when compared to 802.11n Wi-Fi routers using two antennas to transmit and receive data. Actual speeds will vary depending on a number of factors. In order to achieve the best performance, router must be used with a compatible wireless device. †The standard transmission rates--300Mbps or 867Mbps (for 5GHz), 300Mbps (for 2.4GHz), 54Mbps, and 11Mbps--are the physical data rates. Actual data throughput will be lower and may depend on the mix of wireless products used.
  • Up to 2.8x faster than N technology
    It optimized performance for a level of speed and reliable coverage to all your Wi-Fi devices.
  • Dual-band speed
    Get the fastest dual-band speeds for video streaming and gaming - up to 300 Mbps (2.4 GHz) + 867 Mbps (5 GHz)† for delivering maximum speed to multiple devices.
  • Uninterrupted HD movie streaming
  • HIGH-powered signal
  • Parental control
    It blocks unsafe and inappropriate content automatically for all the devices on your network.
  • Backwards compatible
    It works seamlessly with 'N' and 'G' Wi-Fi devices.
  • Four gigabit ports
Belkin F9J1106 - wireless router - DSL modem - Wi-Fi 5 - desktop
Wireless router - DSL modem - 4-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac (draft 2.0)
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
867 Mbps
Network / Transport Protocol
PPTP, L2TP, IPSec
Routing Protocol
Static IP routing
Remote Management Protocol
HTTP
DHCP support, VPN support, parental control, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), IPSec passthrough, Stateful Packet Inspection Firewall (SPIF), MultiBeam technology
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, DLNA CERTIFIED, UPnP, IEEE 802.11ac (draft 2.0)
Microsoft Windows XP SP3, Microsoft Windows Vista (32/64 bits), Apple MacOS X 10.5 - 10.6, Microsoft Windows 7 (32/64 bits)
United Kingdom
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
867 Mbps
PPTP, L2TP, IPSec
Routing Protocol
Static IP routing
HTTP
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2
Authentication Method
Radio Service Set ID (SSID)
Communications
DSL modem
ADSL
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x ADSL - RJ-11 , USB 2.0: 2 x 4 pin USB Type A
Aerial
Aerial
Internal
External power adapter
1 x network cable , 1 x modem cable
United Kingdom
10 - 85% (non-condensing)
8LDS C2G 2m USB 2.0 A/B Cable - Black In Stock £4.17
