Belkin Window + Dash Car Navigation Mount for Smartphones
Quicklinx: BB28WS00 Mfr#: F8M978bt
Device Type: Smartphone
Type: Car Kit
Product Range: Belkin
Product Model: Navigation Mount
£16.46 ex VAT
£19.75 inc VAT
From the small and discreet, to the biggest smartphones on the market, the Car Universal Mount will fit your phone perfectly. Extendable arms firmly cradle your phone, while the mount adheres securely to your windshield or dashboard. Plus, with the ability to tilt and rotate the cradle, it's easy to find the perfect viewing angle for navigation.
  • Big news for big smartphones
    Specially designed to be compatible with some of the biggest smartphones on the market, the Car Universal Mount has extendable arms that can securely hold devices up to 6".
  • Tilt and rotate
    With the ability to tilt and rotate 360 degrees, you'll be able to rotate to landscape view for easier navigation.
  • Cable management
    There's even a place to safely house your charger cable in case you need to charge on the go.
Smartphones
Mount
Device Screen Size
[N/A]
Type: Car Kit
Brand: Belkin
