Belkin WeMo LED Single Light Bulb Edison Screw- F7C033vfE27
Quicklinx: 9Y7QWS00 Mfr#: F7C033vfE27
ENJOY WARM, BRIGHT AND ENERGY EFFICIENT LIGHTING
WeMo Smart LED Bulbs give off warm bright light similar to traditional 60-watt incandescent bulbs and only consume 10 watts of energy. In addition, they have a life expectancy of 23 years (based on 3 hours of daily usage), eliminating the need to replace them as often as incandescent bulbs. LED bulbs also give off less heat than traditional light bulbs, which reduces your home's cooling costs.
Designed to work with the WeMo LED Lighting Starter Set
Turn lights on, off or dim individually or as a group -- from anywhere
Create custom schedules and control for your LED lights individually or as a group
Have your smart bulbs turn on a sunset or have them turn off at sunrise
Simulated Occupancy feature turns your lights on and off automatically making it look like you're home - even when you're not.
WeMo Smart LED Bulbs can gradually dim, so you can fall asleep in a more natural way
Modular system. You can add additional WeMo LED Light Bulbs easily, any time
Intuitive, easy set up and easy to use
Works with the entire family of Belkin WeMo products
Free WeMo App for Android, iOS and Kindle operating systems
Works with IFTTT, connecting you to a whole world of Web apps
WeMo works on multiple smart devices simultaneously
WeMo Smart LED Bulbs have a 23 year life expectancy
Bright, warm light similar to a 60W incandescent bulb
Two-year limited warranty
DEVICE COMPATIBILITY
Android smart devices running Android 4.0 or higher
iOS smart devices running iOS 5 or higher
iPod Touch 3rd Generation and later
iPhone 3GS and later
iPad (all models)
iPad Mini
SYSTEM REQUIREMENTS
WeMo Link Required (Sold Seperately)
Wi-Fi Router with an internet connection
Either Android 4.0 or higher
iOS 5 or higher
WiFi 2.4GHz 802.11n
WeMo App (downloadable from App Store, Google Play Store or Amazon App Store)
PRODUCT SPECIFICATIONS
Form Factor : A19
Connector Type : Edison Screw E26
Input Power : 220-240V, 9.5W, 80mA, 50Hz
Beam Angle : >240°
LED Output Temperature: 3000K
LED Output Brightness : >800 Lumens (60 Watt Incandescent Equivalent)
Dimmable : 50 lumens/watt
Life: 25,000 hours L70
Communications : ZigBee running HA 1.2 supporting "Dimmable Light" clusters.
PACKAGE CONTENTS
1 WeMo Smart LED Bulb
WARRANTY
2 -year Limited Warranty
  • Enjoy warm, bright and energy efficient lighting
    WeMo smart LED bulbs give off warm bright light similar to traditional 60-watt incandescent bulbs and only consume 10 watts of energy. In addition, they have a long life expectancy, eliminating the need to replace them as often as incandescent bulbs. LED bulbs also give off less heat than traditional light bulbs, which reduces your home's cooling costs.
  • Smart LED bulbs can be turned on/off and dimmed from anywhere
    Designed to work with the WeMo LED lighting starter set, WeMo smart LED bulbs replace the traditional light bulbs in your home and can be controlled from your smartphone or tablet from anywhere using your existing Wi-Fi network and mobile Internet. You can program your light to automatically respond to sunset/sunrise, dim it to watch a movie, or turn it off after you leave home - all from your mobile device.
  • Easy to use, easier to install
    WeMo smart LED bulbs install as easily as twisting them into a socket. WeMo smart LED bulbs connect to WeMo Link and are controlled through the WeMo App. Once you screw in your smart LED bulb, open the WeMo App and refresh the content. The WeMo App will register the light bulb and allow you to rename the bulb, change the picture and customize rules. WeMo smart LED bulb keeps you connected to your home lighting anywhere you are - over Wi-Fi, 3G, or 4G networks.
Belkin WeMo Smart - LED light bulb - shape: A19 - E27 - 9.5 W - warm white light - 3000 K
Light Source Type
LED light bulb
Shape
A19
Socket Type
E27
Wattage
9.5 W
Wattage Equivalent
60 W
Colour of Illumination
Warm white light
Colour Temperature
3000 K
Luminous Power
800 lumens
Beam Angle
240 degree(s)
Dimmable
AC 220 - 240 V
Frequency Required
50 Hz
Light Source
LED light bulb
Shape
A19
Socket Type
E27
Wattage
9.5 W
Wattage Equivalent
60 W
Warm white light
Colour Temperature
3000 K
Luminous Power
800 lumens
Luminous Efficacy
50 lm/W
Beam Angle
240 degree(s)
Dimmable
Lifetime
25000 hours
ZigBee Light Link
Power Requirements
AC 220 - 240 V
Frequency Required
50 Hz
Warranty
2 years
