Designed to interface any PC compatible computer to a VGA or SVGA monitor with HDDB15 female connectors. Featuring 24K gold plated corrosion-proof connectors for maximum conductivity.
- Belkin Gold Series VGA cable - 7.5 m
- VGA cable
- Length
- 7.5 m
- Connector
- HD-15 (VGA) - male
- Connector (Second End)
- Black
- Package Type
- Retail
- Limited lifetime warranty
- VGA cable
- Shielding Material
- Aluminium
- Length
- 7.5 m
- Black
- Connector
- 15 pin HD D-Sub (HD-15) - male
- Package Type
- Retail
Customer reviews
Write a review for the Belkin VGA Monitor Replacement Cable here!
Excellent cable!
Reviewed by Matt. Review Posted 17/06/2007
What can i say. I use this cable to connect my PC to my 50" rear projection tv using D-sub 15-pin to 15-pin. Perfect picture, no latnecy, quality at least ten times that of my old s-video connection. At 7.5m length with these features, you'd be silly to pass it by! Dabs delivery as always spot on and fast!
Overall
Ease of use
Value for money
Vga cable
Reviewed by Nick. Review Posted 19/01/2006
I brought this cable to connect to my tv. But found it to be very blurry as if you could see double. I then connected it to my comp monitor and got the same.on inspecting the cable against my orignal monitor cable found i found it to have 15 pin holes but only 14 were used up but my original used all 15 pin holes could not explain so i'm gonna return it.
Overall
Ease of use
Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
