The USB-C to VGA and charge adapter connects to your laptop or tablet via USB-C port, giving you both a VGA port for video display and a USB-C port for power. Its Plug-and-Play design works universally with laptops and other USB-C devices. It offers portable flexibility that's great for classrooms, conferences, and trade shows.
Power and video through a single port
The USB-C to VGA and charge adapter connects to your laptop or tablet via USB-C port, giving you both a VGA port for video display and a USB-C port for power. Its Plug-and-Play design works universally with laptops and other USB-C devices. It offers portable flexibility that's great for classrooms, conferences, and trade shows. -
Charge while you work
Keep your device charged while using your video display all from a single USB-C port. Featuring pass-through USB-C Power Delivery, your device will charge while displaying your content. -
Maintain high-quality video
This cable supports high-definition display on compatible devices.
- Belkin USB-C to VGA + Charge Adapter - adapter - VGA / USB
- Cable
- Adapter - VGA / USB
- Max Output Resolution
- 1920 x 1200 - 60 Hz
- Black
- Connectors
- 24 pin USB-C - male
- Connectors (Second End)
- HD-15 (VGA) - female , USB-C (power only) - female
- 1080p support, USB Power Delivery (60W)
- 2-year warranty
- Cable Type
- Adapter 1080p support, USB Power Delivery (60W)
- Interface Supported
- VGA / USB
- Black
Adapters & Converters
- 1920 x 1200
- Refresh Rate
- 60 Hz
- Connectors
- 15 pin HD D-Sub (HD-15) - female , 24 pin USB-C (power only) - female
- Plug and Play
- 4.3 cm
- 19.15 cm
- 1.16 cm
- Limited warranty - 2 years
