Belkin USB-C to VGA + Charge Adapter (60W PD) - Black
Quicklinx: J79PWS00 Mfr#: AVC001btBK
£38.45 ex VAT
£46.14 inc VAT
The USB-C to VGA and charge adapter connects to your laptop or tablet via USB-C port, giving you both a VGA port for video display and a USB-C port for power. Its Plug-and-Play design works universally with laptops and other USB-C devices. It offers portable flexibility that's great for classrooms, conferences, and trade shows.
  • Power and video through a single port
  • Charge while you work
    Keep your device charged while using your video display all from a single USB-C port. Featuring pass-through USB-C Power Delivery, your device will charge while displaying your content.
  • Maintain high-quality video
    This cable supports high-definition display on compatible devices.
Belkin USB-C to VGA + Charge Adapter - adapter - VGA / USB
Cable
Adapter - VGA / USB
Max Output Resolution
1920 x 1200 - 60 Hz
Connectors
24 pin USB-C - male
Connectors (Second End)
HD-15 (VGA) - female , USB-C (power only) - female
1080p support, USB Power Delivery (60W)
Cable Type
Adapter 1080p support, USB Power Delivery (60W)
Interface Supported
VGA / USB
Adapters & Converters
1920 x 1200
Refresh Rate
60 Hz
Connectors
24 pin USB-C - male
15 pin HD D-Sub (HD-15) - female , 24 pin USB-C (power only) - female
Plug and Play
4.3 cm
19.15 cm
1.16 cm
Brand: Belkin
