Your device now uses a USB-C cable, but why throw out your Micro-USB cables? This small, portable adapter converts your Micro-USB cables to USB-C. Charging up to 12 W and capable of data transfers at up to USB 2.0 it's perfect for charging and syncing. Save money and reduce waste by converting your Micro-USB cables with this adapter.
Essential back-up
This adapter converts your existing Micro-USB cables to USB-C. Now you have a back-up cable that's essential to charging up wherever you are. Ideal for charging in the car, at work, or on-the-go, this cable makes low battery anxiety a thing of the past. -
Slim & compact
The minimal design and high polish finish fit seamlessly with existing USB cables. The small, compact design makes this adapter easy to transport wherever you go. No matter where you go or what you need to charge, you'll be covered.
- Belkin - USB-C adapter - 24 pin USB-C to Micro-USB Type B
- USB-C adapter
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- 5 pin Micro-USB Type B - female
- USB / USB 2.0
- Black
- USB-C adapter
- Black
- Connector
- USB / USB 2.0, USB-IF
