This USB-C to Ethernet and charge adapter provides convenient access to fast and reliable Internet connection through a Gigabit Ethernet port and allows for USB Power Delivery at the same time. It's a Plug-and-Play adapter that works universally with laptops and other USB-C devices.
One port to do it all
This USB-C to Ethernet and charge adapter provides convenient access to fast and reliable Internet connection through a Gigabit Ethernet port and allows for USB Power Delivery at the same time. It's a Plug-and-Play adapter that works universally with laptops and other USB-C devices. -
Don't stop to charge
Connect and stay powered while surfing the Internet or transferring data. Pass-through Power Delivery allows you to stay charged while you work using a single USB-C port. -
Reliable Ethernet connection
Connect with confidence where wireless connectivity is inconsistent or even non-existent. This adapter provides access to a reliable Internet connection for confidently transferring large files or hosting a web conference call without interruption.
- Belkin Ethernet and charge adapter - USB-C - Gigabit Ethernet x 1 + USB-C (power only) x 1
- Ethernet and charge adapter
- Form Factor
- External
- Interface (Bus) Type
- USB-C
- Ports
- 4.1 cm 1.45 cm
- Length
- 19.2 cm
- Cabling Type
- Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
- Data Link Protocol
- 10Mb LAN, 100Mb LAN, 1GbE
- 2-year warranty
- Form Factor
- External
- USB-C
- Ports
- Connectivity Technology
- Wired
- Cabling Type
- USB powered, USB Power Delivery (up to 60 watt)
- 1 x 1000Base-T - RJ-45 - female , 1 x USB (power only) - 24 pin USB-C - female
- 4.1 cm
- 1.45 cm
- Length
- 19.2 cm
- Limited warranty - 2 years
