Belkin USB-C™ to HDMI Adapter
Quicklinx: D2W4WS00 Mfr#: F2CU038btBLK
£32.69 ex VAT
£39.22 inc VAT
The USB-C to HDMI adapter provides a smooth and effortless experience for connecting your USB-C-enabled device to your HDTV, 4K/Ultra HDTV, or any other HDMI-enabled display. This adapter supports 4K @ 60hz, providing stunning clarity and sound for the ultimate viewing experience.
  • Advanced shielding designed to satisfy movie lovers and gamers
    Unlike most conventional video adapters, the Belkin USB-C to HDMI Adapter houses a 6-layer circuit board that delivers uncompromising audio-visual quality. The circuit board, which is protected by Belkin's unique advanced shielding, also keeps EMI (electromagnetic interference) to a minimum, ensuring that you'll enjoy a reliable, high-fidelity signal. And thanks to its meticulous construction and protective coating, the adapter is engineered to withstand tough use.
  • Delivers a vivid, seamless image
    Offering support for 4K resolutions up to 4096x2160 at 60Hz, the Belkin USB-C to HDMI Adapter delivers a clean, crisp picture to render your videos, photos, and games with stunning clarity. Unlike other adapters that only support a 30Hz refresh rate, this 60Hz adapter offers a smooth-moving, seamless image that is free of motion blur. Ideal for High Dynamic Range video, the adapter also supports HDCP 2.2 to stream protected content from iTunes and Netflix.
  • Use with 4K monitors and projectors
    This versatile adapter is compatible with any device that has a video-enabled USB-C port - including certain smartphones, tablets, and laptops. Use it to connect your device to 4K displays, HDTVs, and any other display equipped with an HDMI port. The adapter's reversible USB-C connector connects to your device in any direction, helping ensure a hassle-free connection.
Belkin video interface converter - HDMI / USB
Cable
Video interface converter - HDMI / USB
Max Output Resolution
4096 x 2160 - 60 Hz
Connector
USB-C - male
Connector (Second End)
HDMI - female
Thunderbolt 3
4K support
Works With Chromebook
Cable Type
Video interface converter - 4K support
Interface Supported
HDMI / USB
Thunderbolt 3
HDCP compliant
Adapters & Converters
4096 x 2160
Refresh Rate
60 Hz
Connector
24 pin USB-C - male
19 pin HDMI Type A - female
HDCP 2.2
Brand: Belkin
Price Range Ex VAT: 0 - 50
