Belkin USB-C™ 4-Port Mini Hub
Quicklinx: D2X5WS00 Mfr#: F4U090btBLK
Type: USB Hub
Interface: USB
Ports: 4
£32.32 ex VAT
£38.78 inc VAT
Connect your USB-C laptop, to multiple USB devices with this comprehensive port expansion hub. Two USB-C ports connect devices, while two USB-A ports allow easy connection for existing devices, such as a hard drive, mouse, keyboard or printer. Small and compact, with a tethered USB-C cable, the hub is an ultimately portable and comprehensive peripherals solution.
Connect all your peripherals to your USB-C device with one compact hub. Two USB-A ports connect existing devices, and two dedicated USB-C ports for newer peripherals. Existing or new, your keyboard, mouse, flash drive or cable to sync other devices, will all find a home with this compact hub.
Connect your devices to the hub to sync, and enjoy data transfer of 5 Gbps. That's fast by any standard, let alone a multi-tasking hub that's the size of a pack of playing cards.
  • Ports for portability
  • All devices welcome
  • 5 Gbps speeds
  • Connect anywhere
    Small, compact and lightweight, the 4-Port Mini Hub can slip into your laptop bag and go wherever you go. Plus, the tethered cable that connects the hub to your USB-C laptop folds away inside the hub for neat storage.
Belkin USB-C 4-Port Mini Hub - hub - 4 ports
Hub - 4 ports
Subtype
USB
Ports
4 x SuperSpeed USB 3.0
USB powered
USB 3.0, USB 3.1
Hub - 4 ports
Enclosure Type
Desktop
Subtype
USB
Ports
USB powered
USB 3.0, USB 3.1
2 x USB 3.0 Type A , 2 x USB 3.0 Type C , 1 x USB 3.0 Type C
Type: USB Hub
Interface: USB
Ports: 4
Brand: Belkin
Price Range Ex VAT: 0 - 50
