Now you can attach all your high-speed USB devices to your computer and enjoy error-free transmissions. The Belkin Pro Series Hi-Speed USB 2.0 Cable is the perfect solution for connecting your USB printer, scanner, hard drive, and other equipment. It supports up to 127 devices on a daisy-chain configuration and transmits data at up to 480Mbps. Gold-plated copper contacts provide maximum conductivity and minimize data loss, and hot-pluggable design assures fast connectivity.
- Belkin PRO Series - USB cable - USB to USB Type B - 1.8 m
- USB cable
- Technology
- Shielded
- Molded
- Length
- 1.8 m
- Connector
- 4 pin USB Type A - male
- Connector (Second End)
- 4 pin USB Type B - male
- USB / USB 2.0
- Limited lifetime warranty
- Designed For
- ExpressBus 7-port, Plus; USB Direct Connect
- USB cable
- Technology
- Shielded
- American Wire Gauge (AWG)
- 26
- Plated Connector
- Gold
- Molded
- Length
- 1.8 m
- Connector
- USB / USB 2.0
- Designed For
- Belkin ExpressBus 7-port, Plus , Belkin USB Direct Connect
Customer reviews
Write a review for the Belkin USB A-B device cable 1.8M here!
USB A-B
Reviewed by Anonymous Review Posted 13/07/2004
Good cable, it works.
Overall
Ease of use
Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
