Wirelessly connect up to seven Bluetooth-enabled devices. The Belkin Mini Bluetooth V4.0 Adapter provides cable-free connections to devices up to 10 meters away indoors. This compact, stylish adapter is unobtrusive when plugged into a USB port, and draws minimal energy, so it's perfect to leave plugged in and take anywhere. It is also backward-compatible with legacy Bluetooth technology.
- Belkin USB 4.0 Bluetooth Adapter - network adapter - USB
- Network adapter
- Form Factor
- External
- Interface (Bus) Type
- USB
- 2.2 g
- Data Link Protocol
- Bluetooth 4.0
- Data Transfer Rate
- 3 Mbps
- Frequency Band
- 2.4 GHz
- Bluetooth 4.0
- System Requirements
- Microsoft Windows Vista / XP / 7 / 8
- Network adapter
- Form Factor
- External
- USB
- Connectivity Technology
- Wireless
- Bluetooth 4.0
- 3 Mbps
- Frequency Band
- 2.4 GHz
- Max Range Indoors
- 10 m
- Bluetooth 4.0
Aerial
- Antenna
- Internal
- Connections
- 1 x USB - 4 pin USB Type A
- OS Required
- 2.2 g
