The Belkin USB-C to USB-C cable allows you to charge your USB-C enabled device quickly and safely. Simply plug into any USB-C port to not only charge, but sync and transfer data as well. With a sleek and low profile connector, this cable's minimal design harnesses the incredible power within. Experience 10 Gbps transfer speeds, 20X faster than USB 2.0 (480 Mbps), 12x faster than FireWire 800, and 2X faster than USB 3.0 (5Gbps).
The ultimate usb connection
The Belkin USB-C to USB-C cable allows you to charge your USB-C enabled device quickly and safely. Simply plug into any USB-C port to not only charge, but sync and transfer data as well. With a sleek and low profile connector, this cable's minimal design harnesses the incredible power within. Experience 10 Gbps transfer speeds, 20X faster than USB 2.0 (480 Mbps), 12x faster than FireWire 800, and 2X faster than USB 3.0 (5Gbps). -
USB 3.1: the next evolution
USB 3.1 SuperSpeed+ offers a whole level of connectivity. Transfer data at incredible speeds, charge other devices, and even power mobile devices - all with just one cable. Quickly becoming the universal standard, USB 3.1 is already supported by Windows, Google, and Mac operating systems, as well as many device manufacturers. -
Faster data transfer
Transfer data at up to 10 Gbps with improved cables and connectors. USB 3.1 offers faster rates than ever before. Fast enough to transfer a year's worth of music in 10 minutes or an entire HD movie in just 30 seconds. -
Power & charge other devices
This USB-C cable supports 60 W/3 A of power and can be used for charging and powering USB-C devices. -
Enhanced video & audio resolution
Delivers full audio/video performance, capable of driving monitor resolutions to 4K and beyond. That's four times more resolution than standard HD for a much sharper, clearer and more realistic picture. -
Reversible connector
Never worry about which way to plug in again. USB-C is a user-friendly reversible connector that allows you to connect your cable to your device in any direction -
USB-IF certification
SuperSpeed+ USB compliance means that this cable has been certified by USB-IF to meet all electrical, mechanical, and environmental standards, ensuring a superior user experience. USB-IF is a non-profit organization made up of companies that facilitate the development of high quality USB products and compliance testing.
- Belkin - USB-C cable - 24 pin USB-C to 24 pin USB-C - 1 m
- USB-C cable
- Technology
- Shielded
- 4K support, USB Power Delivery (3A, 60W), sync and charge, 10 Gbps data rate
- Length
- 1 m
- Connector
- 24 pin USB-C - male - reversible
- Connector (Second End)
- USB 3.1
- Black
- USB-C cable
- Technology
- Shielded
- Shielding Material
- Braid
- Jacket Material
- Thermoplastic elastomer (TPE)
- Length
- 1 m
- Black
- Connector
- USB 3.1, USB-IF
