Thinner and lighter computing devices such as Ultrabooks and tablets frequently lack traditional Ethernet ports. Belkin's USB 3.0 Ethernet Adapter gives you the ability to connect to a wired network.
Enhanced connectivity
The Belkin network adapter offers a seamless connection experience, enabling your PC to connect to a wired network with speeds up to 1 Gbps. Its compatibility with Ethernet 1000Base-T, 100Base-TX, and 10Base-T ensures a broad range of network connections. -
High-speed data transfer
With a data transfer rate of 1 Gbps, this adapter is designed for high-speed Internet and network performance. Whether for work or gaming, enjoy a stable and fast connection that keeps up with your demands. -
Easy installation
Featuring a SuperSpeed USB 3.0 interface, this external network adapter ensures a simple Plug-and-Play setup. No additional software or drivers are required, making it a hassle-free addition to your workspace.
- Belkin - network adapter - USB 3.0 - Gigabit Ethernet
- Network adapter
- Form Factor
- External
- Interface (Bus) Type
- SuperSpeed USB 3.0
- Ports
- Gigabit Ethernet
- Cabling Type
- Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
- Data Link Protocol
- 10Mb LAN, 100Mb LAN, 1GbE
- Data Transfer Rate
- 1 Gbps
- Network adapter
- Form Factor
- External
- Ports
- Gigabit Ethernet
- Connectivity Technology
- Wired
- Cabling Type
- 1 Gbps
- 1 x 1000Base-T - RJ-45 - female
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £4.16 |
