Belkin USB 3.0, TYPE C-USB A, 5GBPS,1.5amp, Black
Quicklinx: BG9NWS00 Mfr#: F2CU036btBLK
Length: 12.7cm
Hurry, only 3 left in stock!
£17.68 ex VAT
£21.21 inc VAT
The Belkin USB-C to USB-A adapter allows you to connect your flash drive, keyboard, mouse, or other standard USB-A device to a USB-C enabled device. Plus, the cable also supports up to 1.5 Amps of power output for charging as well as data transfer speeds of up to 5 Gbps.
  • Power & charge other devices
    This USB-C adapter supports up to 1.5A of power output and can be used for charging USB-A devices.
  • Reversible USB-C connector
    Never worry about which way to plug in again. USB-C is a user-friendly reversible connector that allows you to connect your cable to your device in any direction.
Belkin 3.0 USB-C to USB-A Adapter - USB-C adapter
USB-C adapter
Sync and charge
Connector
24 pin USB-C - male - reversible
Connector (Second End)
9 pin USB Type A - female
Rated Current
3 A
USB 3.0
Works With Chromebook
USB-C adapter
Rated Current
3 A
Sync and charge
Connector
USB 3.0, USB-IF
Length: 12.7cm
Brand: Belkin
Price Range Ex VAT: 0 - 50
