Belkin Universal Secure - 2nd Generation - KVM / audio switch - 2 ports - TAA Compliant
Quicklinx: HRSGWS00 Mfr#: F1DN102KVM-UN-4
Hurry, only 3 left in stock!
£546.73 ex VAT
£656.07 inc VAT
Designed to deliver a streamlined user experience when working across security enclaves, Belkin's Universal 2nd Gen Secure KVM switches meet the latest in Common Criteria and NIAP Protection Profile for Peripheral Switching Devices version 4.0 requirements. Optical data diodes and embedded peripheral emulation allow operators to safely share peripherals across multiple security enclaves without exposing potential vectors for attack. Innovative video combo connectors combined with auto-sensing and internal converters make the Universal 2nd Gen SKVM series compatible with modern and legacy systems, eliminating the need for external converters and their inherent cost and compatibility problems. Always on, active anti-tamper and some of the most advanced protections against ultrasonic audio attacks round out the Universal 2nd Gen SKVMs. US-Manufactured and TAA-compliant, these secure KVM series are ideal for use in IT environments that demand rigorous cybersecurity provisions - including government, military, and healthcare applications.
  • Meets the highest standards for cybersecurity
    Ideal for highly sensitive applications that demand isolation between different network security enclaves. The Belkin Universal 2nd Gen Secure KVM Switches utilize optical data diodes and peripheral emulation on each channel to help prevent data leakage between computers while maintaining strict air-gap isolation, even when sharing peripherals. An 8th order elliptical audio filter protects against ultrasonic attacks.
  • Universal video compatibility with combo connector and internal conversion
    DisplayPort/HDMI combo connectors on each input and output allow the same KVM to accommodate systems with DisplayPort, HDMI, and DVI video outputs and modern and legacy monitors, eliminating the need, cost, and uncertainties with external converters. This flexibility enables IT managers to deploy the same, secure KVM switch across their network and prolong the useful life of the KVM simply by matching the appropriate Belkin cable with each connected system and monitor. Cutting-edge video performance delivers up to 4K resolution and 60 Hz refresh on each display.
Subtype
KVM
Ports
2 x KVM / audio
KVM Users Qty
1 local user
CAC reader support
TAA Compliant
Enclosure Type
Desktop
Subtype
KVM
Ports
2 x KVM / audio
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
3840 x 2160 @ 60 Hz
CAC reader support
Status Indicators
Port status
2 x DisplayPort/HDMI input , 1 x DisplayPort/HDMI output , 2 x keyboard (USB) / mouse (USB) Type B , 1 x keyboard (USB) Type A , 1 x mouse (USB) Type A , 1 x audio output mini-jack , 2 x audio input mini-jack , 2 x USB 2.0 Type B common access card (CAC) , 1 x USB 2.0 Type A common access card (CAC) , 1 x management RJ-25
External power adapter
NIAP PP 3.0, FCC Class B certified, UL, ICES, RCM, RoHS
TAA Compliant
Brand: Belkin
Price Range Ex VAT: £500 - £750
