Belkin Universal Micro Car Charger for Apple Products - White
Quicklinx: B9YZWS00 Mfr#: F8J014btWHT
Device Type: iPad, iPad Air, iPad Air 2, iPad Mini + 1 more
£10.62 ex VAT
£12.74 inc VAT
Charge your iPhone 5 on the road with the Belkin Car Charger with included Lightning to USB cable. Get unlimited play and standby time with the low-profile design that sits flush in your dash. Get unlimited play and standby time with the low-profile design that sits flush in your dash. Use the Car Charger with the included 4-foot lightning to USB cable to charge your iPhone 5, iPad or iPad mini at the fastest possible speed. The smaller, more durable lightning connector is also reversible, which makes plugging in it easier than ever. The USB Port is universal, so you can still charge your legacy Apple devices with a 30-pin cable or other devices that use a micro-USB cable. And the included 4-foot lightning to USB cable can be used anywhere - plug it into your laptop to charge and sync, or use your own wall charger to charge from the wall. Great as a replacement cable or if you simply need an extra. Low profile design fits easily in your dash. Rubber grips allow you to insert and remove your lightning car charger with ease. The lightning connector has a reversible design for quick and easy connections.
  • Small but powerful
  • Charge at the speed of lightning
  • USB Port with separate lightning to USB cable
  • Small, compact and easy to use
Belkin Car Charger car power adapter
Car power adapter
White
Output Connector Type
USB
Car power adapter
Enclosure Colour
White
Input Connectors
Automobile cigarette lighter
Output connectors
4 pin USB Type A
Max Electric Current
1 A
LED indicator
WEEE, REACH, Directive 2004/108/EC, RoHS2, Directive 2002/96/EC, Directive 2011/65/EU, Directive 2003/108/EC, Directive 94/62/EC, Directive 2008/34/EC, Regulation EC 1907/2006
Belkin Universal Micro Car Charger for Apple Products - White Bundle deal on Belkin Universal Micro Car Charger for Apple Products - White
£110.38
Device Type: iPad
Device Type: iPad Air
Device Type: iPad Air 2
Device Type: iPad Mini
Device Type: iPod
Brand: Belkin
Price Range Ex VAT: 0 - 50
