Belkin Universal In Car Cup Mount for iPhone & Smartphones
Quicklinx: BB44WS00 Mfr#: F8J168bt
Product Range: Belkin
Product Model: Car Cup Mount
25 in stock
£23.91 ex VAT
£28.69 inc VAT
This cradle fits securely in your car's cup holder and safely positions your compatible iPhone, iPod touch, or Android smartphone within view - no suction cup or adhesive required.
The mount can be rotated 360 degrees so you can position your smartphone in either portrait or landscape mode. Portrait mode is ideal for charging, listening to music, and hands-free phone calls, while landscape view makes using your favorite navigation apps easier. You can also tilt the mount 90 degrees so your smartphone lies flat, keeping it out of the way of your car's controls.
The mount's base expands to fit any size cup holder, so you can use in any vehicle. And because there's no adhesive backing, you can easily move the Car Cup Mount between vehicles.
  • Mount your smartphone in car
  • View in portrait or landscape
  • Expandable base for secure fit
  • Easy cable management
    An opening in the mount's base keeps your phone's connector from getting tangled so it stays neatly connected to your device. This makes it easy to charge your iPhone while mounted using your car's power outlet.
Belkin Car Cup Mount - car holder for mobile phone
Car holder
Intended For
Mobile phone
Suitable For Installation
Car
Apple iPhone 4, 4S, 5, 5s, 6, 6 Plus; Samsung Galaxy Note 3, Note II, S II, S4, S5
Car holder
Intended For
Mobile phone
Car
Rotating 360°, tilt, vertical/horizontal operation
Placing / Mounting
Car cupholder
Apple iPhone 4, 4S, 5, 5s, 6, 6 Plus , Samsung Galaxy Note 3, Note II, S II, S4, S5
Brand: Belkin
Price Range Ex VAT: 0 - 50
