This versatile case makes it easy to go from watch movies to sending emails in one simple motion. Everything about this design is extremely thoughtful - from the soft inner lining that keeps your screen safe and cushioned, to the durable outer construction, and the cover that folds into a stand. And because you want to keep your tablet lightweight and portable, this case protects without adding bulk.
Quality craftsmanship & materials
The Belkin Universal Tri-Fold cover with stand is made of durable, lightweight fabric that's super soft to the touch. It's then molded to the shape of your tablet for an incredibly tailored fit. A velvety smooth inner lining keeps your screen safe and cushioned. -
Cinema viewing angle
Watching movies and videos on your tablet couldn't be more comfortable. Just fold the cover all the way back, and your tablet's propped up at the perfect angle. -
Folds into the perfect angle for typing
The Universal Tri-Fold cover with stand also folds into a lower, more ergonomic angle that puts less stress on your wrists when typing on your touchscreen. -
Strap keeps everything in place
The integrated elastic strap keeps the front cover closed when you're on the go. The same strap can be used to hold the cover back and out of the way while you're using your tablet.
- Belkin Universal Tri-Fold Cover with Stand - protective sleeve for tablet
- Product Type
- Protective sleeve for tablet
- Screen Size Compatibility
- 10"
- Black
- Black
Carrying Case
- Protective sleeve
- Recommended Use
- For tablet
- 10"
- Fold-over cover, elastic strap fastening, soft inner lining
- Cover Features
- Stand function
