Belkin Ultimate Pro Keyboard Case for iPad Air 2 Black
Quicklinx: B2DGWS00 Mfr#: F5L176EABLK
The Belkin Qode Ultimate Pro Keyboard case for iPad Air 2 is the ultimate enhancement to your iPad Air 2 experience. This fully loaded keyboard case combines durable tablet protection, viewing versatility and a totally revamped typing experience, all in one lightweight, portable package.
  • Case works with the keyboard or by itself
    Sometimes you just want to use your iPad Air 2 without the keyboard. While other keyboard case designs make it difficult to remove your tablet, the QODE Ultimate Pro Keyboard Case makes it easier than ever. Simply detach and go - the standalone case keeps you protected. The case by itself even works with your Smart Cover, so your iPad Air 2 always has complete dual-sided protection.
  • Improved keyboard layout
    The Qode Ultimate Pro Keyboard Case is the only keyboard case on the market to have the exact same number of keys as a laptop keyboard, so there's no sacrificing functionality. With a wider keycap shape and improved key pitch, the keys perform better than the competition, making the Ultimate Pro the fastest and most comfortable keyboard case available.
  • Backlit keys with 3 brightness levels
    The QODE Ultimate Pro Keyboard Case also features backlit keys, to make typing in lowlight or no light even easier. Choose between three brightness levels to further customize your typing experience.
  • Pairs with other devices
    Not only does the keyboard wirelessly pair to your iPad Air 2, but you can use it by itself and pair it with other devices. Better still, you can pair up to two devices at once. So when you're typing an email and get a text message on your phone, you can toggle over, respond and get back to your email without skipping a beat.
  • Landscape/portrait modes
    Now you have even more choices when it comes to viewing your iPad Air 2. In addition to the two magnetic viewing angles, you can detach your tablet to position it in either portrait or landscape. Magnets in the case match up with the magnetic fabric hinge for a secure hold in any position.
  • Smart-sensing auto on/off technology
    The keyboard is so smart, there's no need for a power button - it turns on when you need it and off when you don't, simply by sensing the weight of your iPad Air 2. And when you're using the keyboard by itself, it's the fabric hinge that lets it know when to turn on. So no matter which way you prefer to use it, you'll never have to worry about accidentally draining your battery.
  • Longest battery life
    Bluetooth Smart technology also uses less battery power, so you can go longer on one charge - up to 1 year, to be exact.
  • Made of thin, lightweight aluminum alloy
    Known for its strength and amazing lightness, Belkin used anodized aircraft-grade aluminum to make the Qode Ultimate Pro Keyboard Case lighter than the iPad Air 2 itself. So it's incredibly durable, and incredibly portable.
  • Soundflow design enhances sound quality
    The keyboard case's SoundFlow design directs your iPad's sound toward you, making music and movies more powerful and clear than the iPad without the case.
Belkin QODE Ultimate Pro - keyboard and folio case - black
Keyboard and folio case
Backlit
Bluetooth
Smart power management, power saving automatic sleep function
Case Material
Aluminium alloy
Backlit
Bluetooth
Input Device
Carrying Case
Material
Aluminium alloy
Integrated stand, rubber feet, camera lens cutout, detachable internal case, power saving magnet, Smart Cover compatible, port cut-outs, adjustable viewing angles, SoundFlow design, dual-mode positioning, buttons cutout
1 x USB charge cable
