Never suffer from the dreaded low battery again. Belkin Universal mobile chargers are able to charge the greatest number of devices on the market, making them the only chargers you'll ever need. The sleek, compact design is easy on the eyes and you can plug it in virtually anywhere, so a battery boost is always in reach.
USB-C has arrived
Experience all the benefits of USB-C, including the convenient reversible connector, that make it easy to plug in anytime, anywhere. -
2.1A universal charging
The charger connects to your USB-C device using its USB-A port. This universal device-friendly port accepts other cable types so it's easy to connect and charge other devices too. With 2.1 Amps available, use it to charge smartphones, tablets, wearables, or anything that connects via USB-A. -
Multi-talented cable
The sturdy, 6-foot USB-C cable is perfect for at-home charging. The longer length cable reaches easily from your wall outlet to a desk, nightstand or other location. With the capacity to support charging up to 2.1 Amps, it can also be used to connect with other USB-A ports, such as an in-car charger. What's more, with data transfer support up to speeds of 480 Mbps, it's ideal for connecting your USB-C device to a laptop or computer.
- Belkin Universal Home Charger power adapter - USB - 10 Watt
- Product Type
- Power adapter
- Designed For
- Tablet, mobile phone
- Black
- Output Connector Type
- USB - on cable: USB-C
- Max Electric Current
- 2.1 A
- Power Provided
- 10 Watt
- Cables
- USB 3.1 Type A to Type C cable - 1.83 m
- Product Type
- Power adapter
- Designed For
- Enclosure Colour
- Black
- Input Connectors
- Power BS 1363
- Output connectors
- 4 pin USB Type A
- Power Provided
- 10 Watt
- Detachable Cable Connector Type
- USB-C
- 2.1 A
- Cables Included
