Belkin Thunderbolt 3 Dock Pro - Black
Quicklinx: FTT5WS00 Mfr#: F4U097vf
Device Type: Laptop, Macbook
Type: Docking Stations
Device Screen Size: [N/A]
Colour: Black
£425.09 ex VAT
£510.10 inc VAT
The power, speed and pixels of Thunderbolt 3 are best in class, and this smart dock brings all the benefits in a single docking station solution. Compatible with Mac and Windows, simply connect your Thunderbolt 3 or USB-C laptop with the included Thunderbolt 3 cable to instantly create a powerful work station. Enjoy Ultra-High Definition monitor support, up to 40 Gbps transfer rates, 85W of power to your laptop, and support for multiple peripherals via Thunderbolt, USB-A, USB-C, Ethernet, SD and Audio ports, all through a single cable.
  • The ultimate work station
  • Room for all your peripherals
    Enjoy easy access to monitors, networks, power and peripherals with multiple ports available.
  • Thunderbolt 3 cable included
    The dock connects to your Thunderbolt 3 or USB-C laptop through a single cable, which is included in the box. At 2.6ft / 0.8m, this cable is long enough to fit around furniture or reach further from the main outlet, to offer a more versatile desk configuration.
  • Sleek aluminum exterior
    Durable aluminum casing protects the delicate circuitry inside the dock, while presenting a stylish, minimal exterior designed to suit any work space.
  • Dual high-definition monitor support
    Thunderbolt 3 Dock Pro supports dual high-definition monitors for a versatile workspace.
  • Thunderbolt 3 laptop vs USB-C laptop monitor support comparison table
    USB-C host performance will be limited. Note that not all USB-C ports support the full functionality of the USB Type-C standard. USB-C hosts may not support extended display to external monitors.
  • Ultra-High-Speed SD transfer
    The SD (secure digital) card slot supports Ultra-High-Speed II (UHS-II), to transfer data quickly at up to 312 MG/s bus speed. Supporting standard SD cards, SDHC (High-Capacity) cards and SDXC (Extended-Capacity) cards, UHS-II can transfer a full day's camera footage three times faster than UHS-I.
  • Power to share
    With the included 170W power supply unit, the Thunderbolt 3 Dock Pro provides up to 85W of power for a connected laptop. Also known as "upstream charging, " this keeps your laptop charged while in use, without a separate power cable.
Belkin Thunderbolt 3 Dock Pro - docking station - USB-C / Thunderbolt 3 - DP - 1GbE
Docking station
Docking Interface
Video Interfaces
DP
Silver
Gigabit Ethernet
Power adapter DC 20 V 170 Watt Power Provided
Docking station
Enclosure Colour
Silver
Video
Max Resolution Details
5120 x 2880 - 60 Hz
Expansion Slots
SDXC UHS-II Memory Card
4 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x display / video - 20 pin DisplayPort , 1 x USB-C 3.1 Gen 2 - 24 pin USB-C , 1 x USB-C / Thunderbolt 3 - 24 pin USB-C , 1 x audio - headphones/microphone - mini-phone 3.5 mm , 1 x USB-C / Thunderbolt 3 - 24 pin USB-C , 1 x USB 3.1 Gen 1 - 9 pin USB Type A
Input Device
SD card reader
1 x Thunderbolt cable - external - 80 cm
Dual display support, 5K Ultra HD, 85W power delivery
Plug and Play, RoHS
Power adapter
DC 20 V
Power Provided
170 Watt
Windows 8 / 10, Apple macOS 10.12 - 10.14
5 °C
35 °C
Device Type: Laptop
Device Type: Macbook
Colour: Black
Brand: Belkin
