With the Belkin Thunderbolt 2 Express Dock HD, you can connect up to 8 devices (including dual displays) to your powerful Ultrabook, laptop or desktop and take full advantage of Thunderbolt 2 data transfer speeds and 4K cinema resolution.
Transfer Terabytes of files in half the time
The original Thunderbolt Express Dock transfers files at an incredible 10 Gbps. The Thunderbolt 2 technology inside the Belkin Thunderbolt 2 Express Dock HD allows you to transfer at twice that speed - an unprecedented 20 Gbps. That's 4x faster than USB 3.0 and a whopping 25x times faster than Firewire 800. With the Belkin Thunderbolt 2 Express Dock HD, your need for speed has been satisfied. -
Supports dual displays & 4K cinema resolution
Imagine connecting two displays to your laptop. Now imagine one of those displays boasting an eye-popping 4K cinema resolution. With the Belkin Thunderbolt 2 Express Dock HD, you can make the display setup of your dreams a reality. -
Daisy chain additional Thunderbolt devices
Not only can you connect 8 devices directly to your Belkin Thunderbolt 2 Express Dock HD, but you can continue to add up to 4 additional (5 total) Thunderbolt devices by daisy chaining them together. The configuration potential is virtually limitless, allowing you to customize your setup exactly to your needs and specifications.
- Belkin Thunderbolt 2 Express Dock HD - docking station - Thunderbolt - 2 x Mini DP - GigE
- Product Type
- Docking station
- Docking Interface
- Thunderbolt
- Video Interfaces
- 2 x Mini DP
- Brushed aluminum
- Networking
- Gigabit Ethernet
- Power
- Power adapter
- Product Type
- Docking station
- Enclosure Colour
- Brushed aluminum
- Data Link Protocol
- Gigabit Ethernet
- 3 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x network - 10Base-T/100Base-TX/1000Base-TX - RJ-45 , 2 x Thunderbolt 2 - Mini DisplayPort , 1 x audio - line-out - mini-phone stereo 3.5 mm , 1 x microphone - input - mini-phone 3.5 mm , 1 x display / video - 19 pin HDMI Type A
- Cables Included
- 1 x Thunderbolt cable - external - 1 m
- Power Device
- Power adapter
- OS Required
- Microsoft Windows 7 / Windows 8, Apple MacOS X 10.9 or later
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.09 |
