Belkin Thunderbolt™ 3 Express Dock HD with 3.3-ft /1-m Cable
Quicklinx: D2W1WS00 Mfr#: F4U095VF
With speeds of 40 Gbps, the Thunderbolt 3 Express Dock HD has twice the speed of Thunderbolt 2 (20 Gbps) and is 8x faster than USB 3.0 (5 Gbps). That means you can transfer a 4K movie in under 30 seconds! This dock provides up to 85 W of power to your computer which allows you to power your computer & connect to all your peripherals with a single cable. Have more than one 4K display? This dock supports dual 4K displays (DisplayPort and Thunderbolt 3 USB-C) for the ultimate monitor experience. Thunderbolt 3 merges performance and simplicity making the Thunderbolt 3 Express Dock HD the true all-in-one docking solution.
  • Power hitter
    The Thunderbolt 3 Express Dock HD has some serious power. Delivering 85 W of power upstream to your computer means you'll never need an extra power supply.
  • No speed limit
    40 Gbps data transfer rates is fast enough for whatever you plug in. You'll maintain full speed even when fully loaded and running multiple peripherals at once. You can transfer 3 hours of 4K action camera footage in less than a minute.
  • One dock, one cable, one love
    Connect and power with a single cable. Now, one compact port provides Thunderbolt 3 data transfer rates and optimum notebook charging with a single cable. Daisy chain up to 5 additional Thunderbolt devices from the dock. Compatible with Thunderbolt 3 (USB-C) enabled Mac running Mac OS Sierra or later. Please note that the Thunderbolt 3 Express Dock HD is not PC compatible.
  • Dual 4K video output
    For a more immersive experience with life-like detail and rich, vivid colors, the Thunderbolt 3 Express Dock HD supports dual 4K displays, from both the DisplayPort and the Thunderbolt 3 ports.
Belkin Express Dock HD - docking station - Thunderbolt 3 - DP - 1GbE
Docking station
Docking Interface
Thunderbolt 3
Video Interfaces
DP
Gigabit Ethernet
Power adapter 85 Watt Power Provided
Docking station
Gigabit Ethernet
3 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x network - 10Base-T/100Base-TX/1000Base-TX - RJ-45 , 2 x Thunderbolt 3 - 24 pin USB-C , 1 x display / video - DisplayPort - 20 pin DisplayPort , 2 x audio - mini-phone 3.5 mm
1 x Thunderbolt cable - external
Power adapter
Power Provided
85 Watt
Apple macOS Sierra 10.12 or later
