Belkin Textured Grip Candy Slim Cover Case for iPhone 6 Plus - Blue
Quicklinx: BB5PWS00 Mfr#: F8W606btC06
Strength truly comes from smart design. That's why each of iPhone 6 Plus protective cases have gone through a design evolution, making the typical bulky protective case a thing of the past.
  • Dimpled edges for added grip
    The best way to protect your phone is to prevent the chance of damage in the first place. Belkin has revamped the design of the signature color-contrasting edges of the Belkin Grip Candy SE case so your iPhone 6 Plus is even easier to hold. The dimpled texture feels great in hand, and gives you the added security and stabilization you need to prevent accidental drops.
  • Bulk-free damage defense
    The Belkin iPhone 6 Plus Grip Candy SE Case is made of a semi-flexible material that clings to your iPhone 6 Plus like a shock-absorbent second skin. When you put the Belkin Grip Candy SE case on your iPhone 6 Plus, you'll notice that the edges of the case wrap around your phone ever so slightly. Belkin designed the case this way so when you place your phone facedown on a flat surface, your screen is less likely to get scratched - but it's still just as easy to get in and out of your pocket or bag.
  • Easy to take on & off
    Unlike other extreme protection cases, the Grip Candy SE's flexible material makes it quick and easy to take on and off. Now you can change your case as often as you change your look.
  • Full camera & port access
    Belkin Grip Candy SE case is designed to protect the buttons on the sides of your iPhone 6 Plus, while keeping the ports and speakers fully exposed. Adjusting your volume, plugging in your headphones, and connecting your charging cable is fast and easy - all while keeping your case on and your phone fully protected.
Belkin Grip Candy SE - back cover for mobile phone
Back cover for mobile phone
Marine Blue, air
Marine Blue, air
Carrying Case
Protective cover
Recommended Use
For mobile phone
Protection
Scratch-resistant
Cover Type
Back cover
Camera lens cutout, rugged, port cut-outs, buttons cutout, shock absorption
