Belkin Textured Grip Candy Slim Cover Case for iPhone 6 - Blue
Quicklinx: BB3LWS00 Mfr#: F8W502btC06
Rugged protection doesn't have to be overpowering, and that you shouldn't have to choose between a case that gives you peace of mind and one that fits in your pocket. Strength truly comes from smart design. That's why each of the iPhone 6 protective cases have gone through a design evolution, making the typical bulky protective case a thing of the past.
  • Dimpled edges for added grip
    The best way to protect your phone is to prevent the chance of damage in the first place. The dimpled texture feels great in hand, and gives you the added security and stabilization you need to prevent accidental drops.
  • Bulk-free damage defense
    The Belkin iPhone 6 Grip Candy SE case is made of a semi-flexible material that clings to your iPhone 6 like a shock-absorbent second skin. When you put the Belkin Grip Candy SE case on your iPhone 6, you'll notice that the edges of the case wrap around your phone ever so slightly. The case is designed in such a way so when you place your phone face down on a flat surface, your screen is less likely to get scratched - but it's still just as easy to get in and out of your pocket or bag.
  • Easy to take on & off
    Unlike other extreme protection cases, the Grip Candy SE's flexible material makes it quick and easy to take on and off. Now you can change your case as often as you change your look.
  • Full camera & port access
    The Belkin Grip Candy SE case is designed to protect the buttons on the sides of your iPhone 6, while keeping the ports and speakers fully exposed. Adjusting your volume, plugging in your headphones, and connecting your charging cable is fast and easy - all while keeping your case on and your phone fully protected.
Belkin Grip Candy SE - back cover for mobile phone
Back cover for mobile phone
Marine Blue, air
Marine Blue, air
Carrying Case
Protective cover
Recommended Use
For mobile phone
Cover Type
Back cover
Camera lens cutout, rugged, port cut-outs, shock absorption
