Two computers. One monitor. No Problem. Business professionals who bring home their laptops spend countless evenings in front of a small display and cramped keyboard. Thanks to Switch2 for PC, you can now use your big monitor and full-sized keyboard for both your laptop and home computer. It's simple. Just press the remote to switch your monitor from one computer to the next. Switch2 for PC is also great for connecting your old and new desktop computers, so you can access files and programs effortlessly using the same monitor, keyboard, and mouse.
- Belkin Switch2 for PC USB - KVM switch - 2 ports
- Subtype
- KVM
- Ports
- 2 x KVM port(s)
- KVM Users Qty
- 1 local user
- 10.2 cm x 9.5 cm x 2.5 cm
- 369 g
- System Requirements
- Linux, Microsoft Windows Server 2003, Microsoft Windows 98SE/2000/ME/XP
- Localisation
- United Kingdom
- 3-year warranty
- Enclosure Type
- Desktop
- Subtype
- KVM
- Ports
- 2 x KVM port(s)
- KVM Local Users Qty
- 1 local user
- Keyboard / Mouse Interface
- USB
- Max Resolution
- 2048 x 1536 @ 65 Hz
- Status Indicators
- Port status
- 2 x VGA HD-15 , 2 x keyboard (USB) / mouse (USB) Type A , 1 x keyboard (USB) Type A , 1 x VGA HD-15 , 1 x mouse (USB) Type A
- Included Accessories
- Remote control
- Cables Included
- 1 x keyboard / mouse / video cable - 0.6 m , 1 x keyboard / mouse / video cable - 1.8 m , 1 x remote control cable - 1.8 m
- Localisation
- United Kingdom
- OS Required
- 10.2 cm
- 9.5 cm
- 2.5 cm
- 369 g
- Limited warranty - 3 years
Customer reviews
Write a review for the Belkin Switch2 for PC USB - KVM switch - 2 ports here!
Epic piece of kit
Reviewed by Johnny. Review Posted 17/03/2009
Fantastic bit of kit, using it to switch XP home sp3 and a Red hat server - only complaint is that the screen is slightly off centre which is easily fixed by the auto-adjust button on my monitor and it takes a little longer for xp to realise it's back in control(that's a microsoft complaint though!)
would recommend to anyone! Don't buy another monitor!!
Overall
Ease of use
Value for money
Works Great
Reviewed by Henry. Review Posted 11/03/2009
Have a laptop on a docking station and a desktop both running XP. Was a bit unsure how well the switch would work with my wireless keyboard and mouse. Works perfectly everytime, no hanging just swift interaction between both PCs. Fully recomended, not sure how anyone has a problem with this bit of kit!
Overall
Ease of use
Value for money
Great bit of kit
Reviewed by Dylan. Review Posted 12/06/2008
I have two PC's, one running Windows XP, the other running Linux (Ubuntu). I plugged the cables in (took less the 30 seconds), and turned the machines on - worked perfectly. No software to install, no fuss.
Would recommend this product to anyone needing a basic KVM switch.
If I'm being very picky, then I'd complain that switching to the Windows machine takes 1.5 - 2 seconds for the keyboard and mouse to be activated (the monitor is immediate). This delay is not present when switching to the Linux machine. I think the delay is actually Windows, not the switch.
Overall
Ease of use
Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
