Belkin SurgeCube 1-Way Surge Protector w/ 2x 2.4amp USB Charging
Quicklinx: 9RL9WS00 Mfr#: BSV103af
CONVENIENT CHARGING FOR MOBILE DEVICES
Ideal for smaller home and office workspaces, the space-saving SurgeCube 1-Way Surge Protector with USB offers surge protection for your laptop, printer, or hard drive, as well as 2 shared 2.4amp USB ports to charge a mobile device. Keep your tablet or smartphone charged and enjoy peace of mind knowing your hard-to-replace electronic equipment is safe.
  • Single AC Outlet - Wall Mounted Surge Protector
  • 306 Joules of Surge Protection
  • £10k Connected Equipment Warranty
  • Dual Port 2.4A Universal USB Charging (Shared)
  • Ideal for protecting one electronic device at home and while traveling
    Capable of withstanding a power surge of up to 306 Joules, the Belkin BSV 103 1-outlet surge protector is specifically designed to safeguard small electronics. In addition, a surge protection indicator lets you know your equipment is protected.
  • Dual port 2.4AMP universal USB charging (shared) charge mobile devices
    In addition to the 1 outlet, this surge protector features two protected USB charging ports. This allows you to easily charge tablets, smartphones, and other devices powered via USB at the fast speed. These ports make it easy to keep your devices running without blocking your computers, USB ports or the AC outlets you need for larger devices. And with 2.4 Amps between USB ports, they deliver the power needed for fast, efficient charging for iPad Air 2, iPad Mini 3, iPhone 6/iPhone 6Plus and other tablets and smartphones.
  • Secure, portable wall-mountable design
    Damage-resistant housing protects circuits from fire, impact or rust, and prevents dents and scratches.
Belkin SurgeCube - surge protector
Surge protector - external
United Kingdom
Output connectors
1 x power BS 1363 , 2 x 4 pin USB Type A 2.4 A
United Kingdom
Surge Energy Rating
306 Joules
Max Spike Voltage
500 V
Equipment Protection Value
10000 British Pounds
LED indicators, noise filtering, over current protection, Metal Oxide Varistor Technology (MOV)
9RL9 C2G 2m USB 2.0 A/B Cable - Black In Stock £4.02
