CONVENIENT CHARGING FOR MOBILE DEVICES
Ideal for smaller home and office workspaces, the space-saving SurgeCube 1-Way Surge Protector with USB offers surge protection for your laptop, printer, or hard drive, as well as 2 shared 2.4amp USB ports to charge a mobile device. Keep your tablet or smartphone charged and enjoy peace of mind knowing your hard-to-replace electronic equipment is safe.
- Single AC Outlet - Wall Mounted Surge Protector
- 306 Joules of Surge Protection
- £10k Connected Equipment Warranty
- Dual Port 2.4A Universal USB Charging (Shared)
Ideal for protecting one electronic device at home and while traveling
Capable of withstanding a power surge of up to 306 Joules, the Belkin BSV 103 1-outlet surge protector is specifically designed to safeguard small electronics. In addition, a surge protection indicator lets you know your equipment is protected. -
Dual port 2.4AMP universal USB charging (shared) charge mobile devices
In addition to the 1 outlet, this surge protector features two protected USB charging ports. This allows you to easily charge tablets, smartphones, and other devices powered via USB at the fast speed. These ports make it easy to keep your devices running without blocking your computers, USB ports or the AC outlets you need for larger devices. And with 2.4 Amps between USB ports, they deliver the power needed for fast, efficient charging for iPad Air 2, iPad Mini 3, iPhone 6/iPhone 6Plus and other tablets and smartphones. -
Secure, portable wall-mountable design
Damage-resistant housing protects circuits from fire, impact or rust, and prevents dents and scratches.
- Belkin SurgeCube - surge protector
- Surge protector - external
- Localisation
- United Kingdom
- Output connectors
- 1 x power BS 1363 , 2 x 4 pin USB Type A 2.4 A
- Localisation
- United Kingdom
- Power Output Connectors Details
- Surge Energy Rating
- 306 Joules
- Max Spike Voltage
- 500 V
- Equipment Protection Value
- 10000 British Pounds
- LED indicators, noise filtering, over current protection, Metal Oxide Varistor Technology (MOV)
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.74 |
