Store and Charge Go with Portable Trays + Rockstar 10-Port USB Charging Station is the ideal solution to store and charge multiple devices safely and conveniently. A base unit stores up to 10 devices and can be attached securely to a desktop or wall to save space. Removable five-compartment trays add portability for easy transportation. Charge up to 10 USB charging compatible devices at the same time while housing charging cables neatly within the base unit. Universal compatibility means the Store and Charge Go offers solutions for Chromebook⢠computers, laptops, tablets, and more.
All devices welcome
Store and Charge Go with portable trays is the ideal solution to store and charge multiple devices safely and conveniently. A base unit stores up to 10 devices and can be attached securely to a desktop or wall to save space. Removable five-compartment trays add portability for easy transportation. Charge up to 10 USB charging compatible devices at the same time while housing charging cables neatly within the base unit. Universal compatibility means the Store and Charge Go offers solutions for Chromebook computers, laptops, tablets, and more. -
Portability
Two lightweight removable trays fit snugly within the base unit. Each of the five-device trays feature easy-carry ergonomic handles so it's simple to distribute devices to students. -
Multi-device compatible
Universal compatibility accommodates Chromebook computers, laptops, and tablets with or without cases. This means simultaneous charging for different devices, from different brands. Plug in and store your computers and tablets in one location. -
Cost-efficient
With so many features built-in, Store and Charge Go with portable trays offers a high-value solution that delivers a low cost per device - essential for today's cost-sensitive classrooms. The simple, effective, and scalable design keeps installation and setup costs minimal, and requires little to no maintenance on a day-to-day basis.
- Belkin Store and Charge Go with portable trays - charging station - 120 Watt
- Charging station - external
- Power Capacity
- 120 Watt
- Included Accessories
- Mounting base, power supply, 2 x 5 unit portable trays
- 60.5 cm x 32.83 cm x 38.62 cm
- Electric Current per Port
- 2.4 A
- Power Capacity
- 120 Watt
- Equipment Protection Value
- 4000 Euros
- Wall mountable, lockable, surge protection, cable management
- 60.5 cm
- 32.83 cm
- 38.62 cm
