The PC Monitor Cable connects your PC to a VGA or SVGA monitor with HDDB15 female connectors.
- Belkin PRO Series VGA cable - 5 m
- VGA cable
- Technology
- Shielded
- Stranded, thumbscrews
- Length
- 5 m
- Connector
- HD-15 (VGA) - male
- Connector (Second End)
- Limited lifetime warranty
- VGA cable
- Technology
- Shielded
- Shielding Material
- Aluminium
- American Wire Gauge (AWG)
- 28
- Plated Connector
- Gold
- Length
- 5 m
- Connector
- 15 pin HD D-Sub (HD-15) - male
Customer reviews
Write a review for the Belkin Standard VGA signal cable here!
Poor quality
Reviewed by Luca Spiller. Review Posted 03/11/2006
This is a poor quality cable, when connected up I get ghosting (like what you get with a bad tv reception) and the colours are not very bright. It is not a problem with my hardware as I have tried it with another cable and it works fine.
Also the connectors are a bit difficult to screw on, it would probably have been easier if I had used a screwdriver but I didn't have one to hand.
Overall this is a poor product, avoid it at all costs.
Overall
Ease of use
Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
