Belkin Standard VGA signal cable
Customer rating: 1.0* (Write a review)
Quicklinx: TTSWS00 Mfr#: F2N028B05M
The PC Monitor Cable connects your PC to a VGA or SVGA monitor with HDDB15 female connectors.
Belkin PRO Series VGA cable - 5 m
VGA cable
Shielded
Stranded, thumbscrews
Length
5 m
Connector
HD-15 (VGA) - male
Connector (Second End)
HD-15 (VGA) - male
VGA cable
Shielded
Shielding Material
Aluminium
American Wire Gauge (AWG)
28
Plated Connector
Gold
Length
5 m
Connector
Customer reviews
Write a review for the Belkin Standard VGA signal cable here!
Poor quality
Reviewed by Luca Spiller. Review Posted 03/11/2006
This is a poor quality cable, when connected up I get ghosting (like what you get with a bad tv reception) and the colours are not very bright. It is not a problem with my hardware as I have tried it with another cable and it works fine.
Also the connectors are a bit difficult to screw on, it would probably have been easier if I had used a screwdriver but I didn't have one to hand.
Overall this is a poor product, avoid it at all costs.
  • Overall 1*
  • Ease of use 1*
  • Value for money 1*
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
