Belkin SoundForm Isolate Noise Cancelling Headphones - Black
Quicklinx: J79QWS00 Mfr#: AUD008hqBK
Recommended Use: Portable electronics
Connectivity: Wireless, Wired
27 In Stock
£36.83 ex VAT
£44.19 inc VAT
The Belkin SoundForm Isolate headphones offer a blend of performance and comfort designed for portable electronics. Equipped with Bluetooth 5.4 technology, these headphones ensure a seamless wireless connection while providing robust stereo sound output with a frequency response range of 20 - 20,000 Hz. The headphones embrace a full-size ear-parts type for a quality listening experience, enhanced by Hybrid Active Noise Cancelling technology, allowing users to immerse themselves in their favorite tunes without distractions from the surrounding environment.
With a variety of intuitive controls, including power, microphone mute, and volume adjustment, users can easily manage their audio experience. The headphones also feature a built-in microphone that provides clear call quality, making them a great companion for phone calls and voice assistant interactions. Designed for convenience, these headphones are foldable and come with a rechargeable battery, supporting up to 10 m of wireless range while allowing for continuous playback or talk time with active noise-cancelling options. Whether at home or on-the-go, the Belkin SoundForm Isolate headphones deliver a listening experience that you can rely on.
  • Sound quality
    The headphones feature a frequency response range of 20 - 20,000 Hz, delivering clear and vibrant audio across all types of content.
  • Connectivity options
    These headphones offer both wireless Bluetooth connections and wired options with a 3.5 mm jack or USB-C, ensuring compatibility with various devices.
  • Comfortable design
    The headphones are crafted with CloudCushion earpads and an adjustable headband, providing a snug and comfortable fit during extended listening sessions.
  • User-friendly controls
    A series of easy-to-access controls provide users with the ability to manage calls and media playback seamlessly, enhancing the user experience.
  • Eco-friendly construction
    Made from 43.81% post-consumer recycled plastic, these headphones are designed with sustainability in mind while maintaining quality and durability.
Belkin SoundForm Isolate - headphones with mic - USB-C, 3.5 mm jack
Headphones - Bluetooth - wireless, wired - USB-C, 3.5 mm jack
Compatibility
Android phone, Android tablet, iPad, iPhone, Mac
Recommended Use
Headphones Form Factor
Full size
Foldable
Wireless, wired
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 5.4
Sound Output Mode
Stereo
Sound Effects
Signature Sound, Isolate Effect
Audio Specifications
Frequency Response 20 - 20000 Hz
Active Noise Canceling
Noise Isolating
Microphones Included
5
Controls
Microphone on/mute, ANC mode, HearThrough, volume, power on/off, play/pause, next/previous track, voice assistant, accept/end call, reject call
Compatibility
16.8 cm
8.2 cm
18.7 cm
344 g
Body Material
Earpad Material
CloudCushion
Recommended Use
Clear Call Quality microphone technology, status LED indicator, fast charge
Max Operating Distance
10 m
Audio Output
Full size
Foldable
Wireless, wired
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 5.4
Sound Output Mode
Stereo
Sound Effects
Noise Isolating
Active Noise Cancelling Technology
Frequency Response
20 - 20000 Hz
Diaphragm
40 mm
Adjustable Headband
Simultaneously Connectable Devices Qty
2
Microphone
Built-in
5
Remote Control
Controls
Connector Type
Headphones (mini-phone stereo 3.5 mm) , Headphones (USB Type-C)
3.5 mm audio cable, USB-C cable
Cable Details
Audio cable - detachable - 1.2 m , USB-C cable - detachable - 1.2 m
REACH, RoHS, USB-IF
Headphone battery rechargeable
Run Time (Up To)
60 hour(s)
Run Time Details
Continuous playback (active noise-cancelling off): up to 60 hours , Continuous playback (active noise-cancelling on): up to 40 hours , Continuous talk (active noise-cancelling off): up to 35 hours , Continuous talk (active noise-cancelling on): up to 30 hours
Recharge Time
2 hour(s)
Min Storage Temperature
-40 °C
Max Storage Temperature
85 °C
10 - 90% RH
Humidity Range Storage
5 - 95% RH
Connectivity: Wired
Brand: Belkin
