Belkin SoundForm Adapt headphones combine innovative technology with user-friendly features to deliver a high-quality audio experience. With Bluetooth 5.2, users enjoy a stable, high-quality wireless connection, while the option for wired connectivity through USB-C or 3.5 mm jack adds versatility. Environmental Noise Cancellation (ENC) technology ensures that your listening experience is free from unwanted background noise, providing crystal-clear sound. The headphones are designed for comfort, with an adjustable headband, full-size ear parts, and a foldable structure for easy storage. Additionally, the device supports fast charging and multipoint pairing, making it ideal for on-the-go use. Crafted from sustainable materials and compliant with major environmental standards, the Belkin SoundForm Adapt headphones are an excellent choice for eco-conscious consumers seeking a high-performance audio solution.
Advanced connectivity
Equipped with Bluetooth 5.2 and both USB-C and 3.5 mm jack interfaces, this device offers seamless connectivity options, whether wired or wireless. The ability to connect to two devices simultaneously enhances user convenience and flexibility. -
High-quality sound
Featuring Environmental Noise Cancellation (ENC) technology and a 40 mm diaphragm, the headphones deliver clear, high-quality stereo sound. The full-size ear parts ensure a comfortable listening experience, even during extended use. -
User-friendly design
With features like foldable design, adjustable headband, and flip-to-mute controls, these headphones are crafted for ease of use. The touch control for fast charge and multipoint pairing adds to the seamless user experience. -
Eco-conscious construction
Made from post-consumer recycled plastic and compliant with REACH, RoHS, and USB-IF standards, these headphones are designed with sustainability in mind. The foam earpads offer comfort without compromising on environmental values.
- Belkin SoundForm Adapt - headphones with mic - USB-C, 3.5 mm jack
- Product Type
- Headphones - Bluetooth - wireless, wired - USB-C, 3.5 mm jack
- Recommended Use
- Portable electronics
- Black
- Headphones Form Factor
- Full size
- Foldable
- Connectivity Technology
- Wireless, wired
- Wireless Technology
- Bluetooth
- Bluetooth Version
- Bluetooth 5.2
- Sound Output Mode
- Stereo
- Microphone
- Boom
- Microphone Noise Cancelling
- Controls
- Flip-to-mute, volume, power on/off, pair mode
- 2-year warranty
- Product Type
- Black
- Body Material
- Post-consumer recycled plastic
- Earpad Material
- Foam
- Recommended Use
- Fast charge, Multipoint Pairing, touch control
- Max Operating Distance
- 10 m
Audio Output
- Full size
- Foldable
- Wireless, wired
- Bluetooth
- Bluetooth Version
- Bluetooth 5.2
- Sound Output Mode
- Stereo
- Max Sound Pressure
- 98 dB
- Diaphragm
- 40 mm
- Adjustable Headband
- Simultaneously Connectable Devices Qty
- 2
Microphone
- Boom
- Noise Cancelling
- Noise Cancelling Technology
- Environmental Noise Cancellation (ENC)
Remote Control
- Controls
- Connector Type
- Headphones (mini-phone stereo 3.5 mm) , Headphones (USB Type-C)
- Included Accessories
- USB-C to USB-C cable, 3.5 mm audio cable
- Cable Details
- USB-C to USB-C cable - detachable - 1 m , Audio cable - detachable - 1.2 m
- RoHS, USB-IF, REACH
- Battery
- Headphone battery rechargeable
- Run Time (Up To)
- 65 hour(s)
- Run Time Details
- Continuous playback: up to 65 hours
- Recharge Time
- 2 hour(s)
- Limited warranty - 2 years
- 0 °C
- 40 °C
- Min Storage Temperature
- -30 °C
- Max Storage Temperature
- 70 °C
- 10 - 90% RH
- Humidity Range Storage
- 5 - 95% RH
