Snap Shield is a fast and simple way to protect MacBooks and Chromebooks in the classroom. A customized fit ensures installation is easy, and requires little set up and maintenance after application. The two-part, slim-fit case offers scratch protection for devices, top and bottom, and works seamlessly with convertible or touchscreen models. Retractable feet on the bottom of the case provide adjustable keyboard angles to make typing easy.
Impact-resistant design
Crafted from durable polycarbonate, this notebook cover offers robust protection against impacts, ensuring your device remains safe from accidental drops and bumps. -
Scratch-proof protection
The Belkin Snap Shield for HP G4 (11-inch Case) is designed to keep your notebook looking pristine by guarding against scratches and scuffs, maintaining the aesthetic appeal of your device. -
Convenient built-in stand
Enhance your viewing and typing experience with the built-in stand feature, allowing for adjustable angles that cater to your comfort and usability needs.
- Belkin Snap Shield for HP G4 (11-inch Case) - notebook cover
- Product Type
- Notebook cover
- Translucent
- Product Material
- Polycarbonate
- Notebook Compatibility
- 11"
- Impact resistant, scratch-proof, built-in stand
- Designed For
- HP Chromebook 11 G4
- Product Type
- Notebook cover
- Product Material
- Polycarbonate
- 11"
- Translucent
- Designed For
