Belkin Smooth Tri-Fold Cover with Stand for Galaxy Tab 3 10.1" - Blacktop
Quicklinx: 8TH0WS00 Mfr#: F7P122vfC00
This versatile case makes it easy to go from watch movies to sending emails in one simple motion. Everything about this design is extremely thoughtful - from the soft inner lining that keeps your screen safe and cushioned, to the durable outer construction, and the cover that folds into a stand. And because you want to keep your tablet lightweight and portable, this case protects without adding bulk.
The Smooth Tri-Fold Cover with Stand is designed first and foremost to keep your tablet safe and secure. It features an x-frame design with tooled corners that fit snugly around the Samsung Galaxy Tab 3 10.1.
The Belkin Smooth Tri-Fold Cover with Stand is made of durable, lightweight fabric that's super soft to the touch. It's then molded to the shape of your Galaxy Tab for an incredibly tailored fit. A velvety smooth inner lining keeps your screen safe and cushioned.
Watching movies and videos on your Galaxy Tab couldn't be more comfortable. Just fold the cover all the way back, and your tablet's propped up at the perfect angle.
The Smooth Tri-Fold Cover with Stand also folds into a lower, more ergonomic angle that puts less stress on your wrists when typing on your touchscreen.
The integrated elastic strap keeps the front cover closed when you're on the go. The same strap can be used to hold the cover back and out of the way while you're using your tablet.
  • Work, play, protect
  • Secure fit
  • Quality craftsmanship & materials
  • Cinema viewing angle
  • Folds into the perfect angle for typing
  • Strap keeps everything in place
Belkin Smooth Tri-Fold Cover with Stand - case for tablet
Case for tablet
Material
Fabric
Samsung Galaxy Tab 3 (10.1 in)
Material
Fabric
Carrying Case
Case
Recommended Use
For tablet
Closure Type
Closure strap
Elastic strap fastening, soft inner lining
Cover Features
Stand function
