Belkin Slim-Fit Plus Armband for iPhone 6 - Pink
NEED A MOBILE TARIFF ??? SEE DESCRIPTION BELOW
Quicklinx: 9S28WS00 Mfr#: F8W499BTC01
The high-performance Slim-Fit Plus iPhone 6 Armband doesn't just protect your phone while you're exercising - it's also incredibly comfortable to wear. The secure fit and slim design stays out of your way, so you forget you're even wearing it. Now you can concentrate on your workout, not your device.
  • Reflective stripe for nighttime visibility
    A reflective stripe on the armband helps keep you safe by making you more visible when you're running, walking, or biking - even in the evening.
  • Cord storage
    With the Slim-Fit Plus iPhone 6 Armband's Cord Storage feature, you'll never get tangled up in your headphone cords again. Belkin integrated it into the strap, so all you have to do is gather up the extra cord length, and it stays out of your way.
  • Easy to adjust
    Belkin designed the Slim-Fit Plus iPhone 6 Armband with a larger loop for the strap for two reasons: One, so it's easier to adjust to the fit that's most comfortable for you; and two, it keeps your skin from getting pinched or irritated.
  • Slim and stylish
    The Slim-Fit Plus Armband for iPhone 6 is made of stretchy neoprene material that's hand-washable and perforated for added breathability. It fits snug against your arm to give you full access to your screen without adding extra bulk. Reflective fabric accents keep you safe and visible to others.
Belkin Slim-Fit Plus Armband - arm pack for mobile phone
Arm pack for mobile phone
Material
Neoprene
Fuchsia
Material
Neoprene
Fuchsia
Carrying Case
Arm pack
Recommended Use
For mobile phone
Washable
Carrying Strap
Arm band
Adjustable straps, clear screen protector, cord storage, reflective stripe
