The Grip Case for iPhone 6 Plus safeguards your phone from damage without adding bulk. Constructed from a shock-absorbent material, this case protects your iPhone 6 Plus from drops, impacts, scratches, and other types of damage. Its form-fitting design preserves the slim profile of your phone, so you don't feel anything extra when you're carrying it in your pocket.
High-friction material is easy to grip
The Grip Case is made to be handled and gripped. Constructed from a flexible, high-friction polymer, it delivers premium protection without feeling stiff. The case gives you a firmer grasp on your phone when you're holding it and also protects your iPhone 6 Plus from slipping when you place it on a surface. -
Wraps around to protect on all sides
The Grip Case has a wraparound design that forms a slight bezel to keep your phone elevated when placed face-down. You'll have peace of mind knowing your screen is protected against scratches and scuffs. -
Full access to buttons, ports, and camera
With its thoughtfully placed cutouts, the Grip Case leaves iPhone 6 Plus buttons and features fully exposed. It gives you easy access to the volume control, power on/off, headphone jack, camera and flash, and lightning port. -
Easy to apply and remove
Thanks to its soft, flexible materials, the Grip Case can be removed easily if you need access to your phone's battery compartment or SIM card. The case's wraparound design slips onto your phone like a glove and can be peeled off without any hassle.
- Belkin Grip - back cover for mobile phone
- Product Type
- Back cover for mobile phone
- Material
- Polymer
- Blue
- Material
- Polymer
- Blue
Carrying Case
- Protective cover
- Recommended Use
- For mobile phone
- Protection
- Scratch-resistant, impact protection, drop-proof
- Cover Type
- Back cover
- Camera lens cutout, port cut-outs, shock absorption
