Belkin ScreenForce UltraGlass 2 for iPhone 15 Pro
Quicklinx: HKRSWS00 Mfr#: OVA133ZZ
26 In Stock
£26.46 ex VAT
£31.75 inc VAT
Now up to 2.7x stronger than tempered glass. UltraGlass 2 screen protectors are stronger and durable. They're engineered to look and feel just like your iPhone screen and protect against impact, scratches, cracks, smudges, fingerprints, and more. The glass contains an antimicrobial treatment to protect the product from discoloration and degradation.
  • Stronger screen protector
    Up to 2.7x stronger than standard protection, UltraGlass 2 screen protectors are chemically enhanced through double-ion exchange to be a durable. With the highest rating (9H) on the Pencil Hardness scale, your screen is protected from scratches and keeps it clean and clear for optimal viewing.
  • Proven protection with 20-step testing
    With a rigorous testing process, you're ensured unparalleled protection from impact, chemicals, heat conditions, and scratches. They're also drop-tested, tumble-tested, fit-tested, and assured to be just as strong at the edges as the center.
  • As thin as two pieces of paper
    Although they're just 0.29 mm thin, they offer unparalleled protection without losing the touchscreen experience you're used to. UltraGlass 2 screen protectors are designed to look and feel just like your iPhone screen.
  • Clear as day, every day
    At near-complete clarity, UltraGlass 2 is fingerprint and smudge-resistant and comes with an antimicrobial coating that prevents discoloration. Your videos and photos stay looking crystal clear, exactly as they're intended to be seen.
  • Simple, precise application
    Your full screen is covered with the protectors that are compatible with iPhone and iPhone cases. They also come with an Easy Align tray that helps with fast, easy, and bubble-free application.
Belkin ScreenForce UltraGlass 2 - screen protector for mobile phone - 9H, treated
Screen protector - glass
Intended For
Mobile phone
Protection
Chemical-resistant, impact protection, smudge-proof, heat-resistant, scratch protection, discolouration resistant, fingerprint-resistant, crack-resistant
Coating
Antimicrobial
Package Content
Cleaning cloth, screen protector, dust removal sticker, Easy align tray
Thickness
0.29 mm
Apple iPhone 15 Pro
Intended For
Mobile phone
Protection
Package Content
Coating
Antimicrobial
Thickness
0.29 mm
Limited warranty - lifetime , Money back guarantee - 90 days
Apple iPhone 15 Pro
Brand: Belkin
