TrueClear advanced screen protector for Galaxy S6 is the best screen protector available, engineered for strength and clarity and tested to meet optometric standards. The result is a crystal clear screen protector that keeps your screen safe from damage while still giving you an incredible screen experience.
Pixel for pixel, clearest protection
The TrueClear technology allows light to pass through screen protectors precisely and evenly, giving you a level of sharpness and vibrancy higher than even the leading competitor's high-definition products. -
Market leader in clarity
The screen protectors are tested for optical precision and clarity using the same methods optometrists use for eyeglasses. These tests, combined with third-party data, position TrueClear Galaxy S6 screen protectors as the market leaders in clarity - the clearest screen protection you can buy. -
Fast, easy application
Applying your Galaxy S6 screen protector is fast and easy. Start by cleaning your screen with the included cleaning wipe and dust removal film, then peel the overlay from its backing and place it onto your screen. Finish by using the included smoothing card to push away creases and bubbles.
- Belkin TrueClear - screen protector for mobile phone
- Product Type
- Screen protector
- Intended For
- Mobile phone
- Protection
- Scratch-resistant
- Package Content
- 3 screen protectors, smoothing card, cleaning wipe, dust removal sticker
- Transparent
- Limited lifetime warranty
- Product Type
- Screen protector
- Intended For
- Mobile phone
- Protection
- Scratch-resistant
- Package Content
- Transparent
- Lifetime
