TrueClear advanced screen protection for Galaxy Tab 4 7.0 is the best screen protector available, engineered for strength and clarity and tested to meet optometric standards. The result is a crystal clear screen protector that keeps your screen safe from damage while still giving you an incredible screen experience.
Pixel for pixel, clearest protection available
Patented TrueClear technology allows light to pass through this screen protectors precisely and evenly, giving you a level of sharpness and vibrancy higher than even the leading competitor's high-definition products. -
Market leader in visibility
Belkin screen protectors are tested for optical precision and clarity using the same methods optometrists use for eyeglasses. These tests, combined with third-party data, position TrueClear Galaxy Tab 4 7.0 screen protectors as the market leaders in visibility - the clearest screen protection you can buy. -
Fast, easy application
Applying your Galaxy Tab 4 7.0 screen protector is fast and easy. Start by cleaning your screen with the included cleaning wipe and dust removal film, then peel the overlay from its backing and place it onto your screen. Finish by using the included smoothing card to push away creases and bubbles. -
Case-compatible
TrueClear Advanced Screen Protectors fit your Galaxy Tab 4 7.0's screen perfectly, and are designed to work with any case to give you 360° protection. Strong yet thin and lightweight, this Galaxy Tab 4 7.0 screen protector provides excellent defense against damage that will help keep your device looking like new.
- Belkin - screen protector for tablet
- Product Type
- Screen protector
- Intended For
- Tablet
- Protection
- Scratch-resistant
- Transparent
- Designed For
- Samsung Galaxy Tab 4 (7 in)
- Product Type
- Screen protector
- Intended For
- Tablet
- Protection
- Scratch-resistant
- Transparent
- Designed For
