Belkin ROCKSTAR USB-C In-Ear Headphone - Black
Quicklinx: FCWWWS00 Mfr#: G3H0002btBLK
Type: Earphones
Connectivity: Wired
Colour: Black
Hurry, only 2 left in stock!
£9.06 ex VAT
£10.87 inc VAT
With high quality sound, supreme comfort and fit, and exceptional durability, ROCKSTAR Headphones with USB-C connector are the headphones you, and your USB-C smartphone, have been waiting for. Packed with features, including water-resistance and noise-isolation, these compact headphones deliver superior audio without distraction – so you can lose yourself in music, be transported to a different world with an audio book, or experience the highs and lows of every story with compelling podcast content.
  • A perfect fit for superior sound
    Perfectly-fitting earphones create a far superior sound. ROCKSTAR combines ear tips that can be tailored to your ear, with a design that actively directs the sound towards your eardrum. The result is excellent noise isolation, so you can be sure you are experiencing the music as the artist intended. Every drumbeat, every lyric, every instrument and every breath in the original recording is clearly replicated for your ear. With playback this flawless, the only thing that might get lost is you.
  • Find your new comfort zone
    Poorly-fitting earbuds are a main contributor to headphone discomfort. With three differently-sized ear tips provided with ROCKSTAR, it's easy to find the right fit for a more comfortable listening experience. Holding the ear tips, angled drivers reduce strain on your ear, so you can enjoy all-day comfort, and listen to the music you love, for as long as you like.
  • Sweat-resistant and splash-resistant
    Wherever you listen to music, your ROCKSTAR headphones are designed to go with you.
  • Quality means durability
    ROCKSTAR headphones are highly flexible and reinforced at major stress points, to withstand heavy use in multiple environments. Comprehensive testing procedures, covering everything from sustained usage to extreme environmental conditions, guarantee durability. Great music stands the test of time, so do our headphones.
  • Tangle-free
    The flat, lightweight design keeps the headphone cable tangle-free in a pocket or bag. When in use, the cable management feature keeps excess cable out of your way, and positions the microphone for easy, hands-free calling.
  • Putting you in control
    Your ROCKSTAR headphones are ready to use straight out of the box - no adapter or prior charging required. The multi-control button makes it easy to play, pause, skip tracks, change volume or answer a phone call at the touch of a button. The clear, built-in microphone makes it easy to take calls without removing the earphones.
Belkin ROCKSTAR - earphones with mic - USB-C
Earphones - wired - USB-C
Recommended Use
Portable electronics
Headphones Form Factor
In-ear
Wired
Sound Output Mode
Stereo
Noise Isolating
Microphone
On-cable
Controls
Volume, answer/end, play/pause, next/previous track
Body Material
Post-consumer recycled plastic
Recommended Use
Protection
Splashproof, sweat-resistant, water-resistant
Audio Output
In-ear
Wired
Sound Output Mode
Stereo
Noise Isolating
In-Cord Volume Control
Microphone
On-cable
Remote Control
Controls
Connector Type
Headphones (24 pin USB-C)
Cable
Cable Length
1.12 m
3 pairs of silicone ear tips (small, medium, large)
Cable Details
Headphones cable - anti tangle - 1.12 m
Type: Earphones
Connectivity: Wired
Colour: Black
Brand: Belkin
