Belkin Powerline AV 200Mbps Pass-Through Kit
Quicklinx: 77VRWS00 Mfr#: F5D4079UK
The Surf Powerline AV+ Passthrough will easily connect your Internet TV, game console or Blu-Ray Live player to the web through any wall socket in your home. The sllim pass-through design to connect prevents wall sockets from being blocked.
Surf Powerline AV+ allows you to reliably transmit content from your Internet directly to your computer and other network devices through the electrical wires in your home. Transfer speeds of up to 200Mpbs makes the Surf Powerline AV+ ideal for streaming media to your home entertainment devices such as gaming consoles and set-top boxes.
Setup of Powerline is simple with its plug-and-play connectivity. Connect one adapter to your router and plug it into an available electrical outlet. Plug the second adpter into an available wall outlet and connect the other end to any device with an available Ethernet port such as a gaming console, set-top box, or computer.
Belkin F5D4079 - powerline adapter kit - desktop
Powerline adapter kit
Packaged Quantity
2 (specifications are for single item)
Enclosure Type
Desktop
Ethernet, Fast Ethernet, HomePlug AV (HPAV)
Data Transfer Rate
200 Mbps
IEEE 802.3, HomePlug AV
United Kingdom
Packaged Quantity
Enclosure Type
Desktop
Wired
Data Transfer Rate
200 Mbps
Encryption Algorithm
128-bit AES
Status Indicators
Port status, power, status
1 x 100Base-TX - RJ-45 , 1 x HomePlug AV
Internal power supply
1 x network cable
United Kingdom
Software Included
Drivers & Utilities
Additional Requirements
CD-ROM
10 - 90% (non-condensing)
