Belkin Power Bank 10K - Black
Quicklinx: HBPFWS00 Mfr#: BPB011btBK
Device Type: [N/A]
Type: Power Bank
Product Range: Belkin BoostCharge
Product Model: [N/A]
14 In Stock
£19.16 ex VAT
£22.99 inc VAT
Express delivery Delivered on Wednesday
Charge 3 devices at once with a 10K portable charger that’s as versatile as it is convenient. Two USB-A ports and one USB-C port provide up to 15W of power at once for your smart phone and two other devices. An included USB-A to USB-C cable lets you start charging right away.
  • Charge 3 devices at once
    Two USB-A ports and one USB-C port keep all your devices charged, providing up to 15W of power for your smartphone and two other accessories. Charge at up to 15W when using all 3 ports, adding up to an additional 40 hours of battery life for your smartphone. Binge watch movies, take video calls, and keep your navigation apps running all the way to your destination. An LED light indicates when the power bank needs recharging, and the included USB-A to USB-C cable lets you start charging right out of the box.
  • Up to an additional 40 hours of battery life
    10,000 mAh of power fully recharges an iPhone 12 twice, and keeps your smart devices running when an outlet is out of reach.
  • Versatile power for 3 devices at once
    Charge your smartphone and other devices with up to 15W of power from 2 USB-A ports and 1 USB-C port.
  • Charging cable included
    A USB-A to USB-C cable is included so you can start charging right out of the box, and it can also be used to recharge the power bank when needed.
  • LED indicator light
    An LED light tells you the power bank's power status, so you always know when it's time to recharge.
Belkin BoostCharge power bank - 24 pin USB-C, 2 x USB - 15 Watt
Power bank
Tablet, mobile phone
13.183 cm x 6.833 cm x 1.575 cm
222 g
Output Connector Type
Total 3: 24 pin USB-C, 2 x USB
10000 mAh
Power Provided
15 Watt
Cables
USB-A to USB-C power cable
Power bank
13.183 cm
6.833 cm
1.575 cm
222 g
Enclosure Colour
Output connectors
Total 3: 24 pin USB-C, 2 x 4 pin USB Type A
Power Provided
15 Watt
LED indicator
10000 mAh
Equipment Protection Value
2500 US Dollars
Material
Post-consumer recycled plastic
Device Type: [N/A]
Type: Power Bank
Brand: Belkin
